Sunfamily267
- 5
- 3
- Virginia
I did something to make the Thermal Flasher self-destruct…TWICE. (searched the forum for Burnt Flasher, Flasher, exploded Flasher...but did not find one related to my issue. If there is one, please forward to me. thanks.)
I have a 1999 M1097A2. Working on it for the past couple months off-n-on getting it road legal.
Situation:
Before replacing the Flasher, most of the incandescent lights were blown or not working. I checked the turn signal switch using TM 9-2320-280-20-1; pg 2-396-397. Ops Check good. I also checked for 24V on 325A (Pin A of Flasher cannon plug) while the turn signal was in the Left, Right, and Hazard positions. G2G (24.6V). I checked for a good ground on 57K (Pin C of Flasher cannon plug). G2G.I replaced the incandescent turn signal/running lights with LED bulbs and replaced Thermal Flasher NSN 5945-00-789-3706 with NSN 5945-01-584-9793 (works with LEDs and incandescent bulbs). The new flasher was not mounted, I just let it hang, I ops checked turn signals and hazards and all G2G. All the lights were working.
At the time of the Ops Check:
- Engine was off, just using battery power.
- The flasher was not permanently mounted, just hanging
- The battery was connected through a disconnect I installed on the negative side
- The Transmission 12V power was disconnected from battery and the 12V line from the Alternator disconnected. This was just because I was working on those items related to a separate task.
A few hours after the turn signal Ops Check, I was ready to check a few more things:
- I mounted the Flasher properly
- connected the Transmission 12V cable to the battery, yes to the correct battery terminal.
- connected the Alternator 12V cable to the battery, yes to the correct and same terminal.
- Closed the hood
- Engine is off
Not sure if this is related to the issue but when the 12V alternator cable is connected and the disconnect is open/off, I have a residual 3.3V floating.
So, I closed the disconnect and turned on the Lights (Serv. Drive and Dim). Lights all worked fine. Moved turn signal to Left position and went to check front signal, POP! and then the lovely smell of burnt electrical. Several bad words announced since this was the second one I blew-up, I thought I found the issues before (corroded bulb and bad wire...thinking these may have led to a short)
Hard to see in the picture but one of the 3 leads on the transistor is broken which I assume was the one with the juice on it to make it blowup.
![Flasher explosion.jpg Flasher explosion.jpg](https://www.steelsoldiers.com/data/attachments/651/651857-656f02cb29e5f15f4497d0c16da53448.jpg)
Anyone else experience this? What was it and what was the fix?
Been trying to figure it out for a week now but stuck. Well, that is it. Can’t really afford to keep blowing these things up while troubleshooting. NaFC
Thank you for reading to the end. Please don't ask me why I changed to LEDs or "Why you did this or that..." Just some helpful hints on how to move forward if any ("did you try this or that...), Much appreciated!
Situation:
- Closed the hood
- Engine is off
