SasquatchSanta
- 18
- 0
- Northern Minnesota
I have concerns about a thermostat we installed in my M37 today.
I swapped the existing, stock 180 degree thermostat for a 195 degree unit because the engine wasn't heating up and I was about to freeze my "whatever" off.
As you may know, the M37 has a by-pass on the top of the water pump and a rather large, conventional looking old style thermostat. The thermostat the parts house delivered was a different style thermostat --- new style --- that looks more like a flying saucer than the old, original thermostat. The new unit sets low in the head/neck and therefore, from what I can tell isn't going to allow the bypass to work.
Some of the 230 civilian flatheads had a different water pump without the bypass BUT there was a bypass port (hole) in the front of the block and engine head.
Given that the M37 block and head doesn't have the bypass port I'm concerned that I may be making a mistake by installing a thermostat that "MIGHT" not allow the bypass in the water pump to work properly.
I tend to be a worrier therefore I may be jumping at shadows. BUT, I sure as heck don't want to kill a perfectly good engine because of something as simple as a thermostat.
Is the bypass really needed?
Any input would be appeciated.
