This is going to be interesting
frank8003
4,984
Ft. Lauderdale, Florida
I committed to refurbish whatever necessary on my '69 NG truck brakes. Work, work + time gone and more work and the money gone. So what, I like the truck.
From the miles and hours on the truck I see that last time it was "fixed" maybe was back in the 80's or sometimes I think never.
This is the last of the six axles to be done. None of the axles had a keyway seal and all were improper in one way or a few ways;
springs landed in wrong place, blown or rotted or froze or non-functional wheel cylinders, bolts loose or over-torqued; wasted away shoes, bent hard lines to wheel cylinders, etc and all that You all have seen, and learned to forget and just fix it.
But I think this RR tandem, the last one is going to be interesting............
porkysplace
1,488
mid- michigan
What makes you think the miles and hours are correct ? The military swaps gauges like tires , if something isn't working right swap it out.
frank8003
4,984
now beyond just interesting 06192014
No tabs bent, no gasket, no keyway seal, no grease inside bearings, bent up dust cover, shoes wiped out and "frozen" in one place, forward minor adjuster broke off, wheel cylinder rotted away, broken parts all found, and I still think it is strange how far away a 1/2" lockwasher can disappear to.
Now I have to hit the books and find how to fix the adjuster.
photo 5.jpgphoto 6.jpgphoto 8.jpgphoto 17.jpgphoto 20.jpgphoto 25.jpgphoto 26.jpgphoto 19.jpgphoto 21.jpg
Warthog
232
OKC, OK
Good thing you decided to check your brakes instead of just driving it.
At least now you will "know" what the condition is.
Good job!!!
texas30cal
87
Brenham Tx.
That's exactly right, any job worth doing is worth doing right, this is the same way I approach any used vehicle no matter what it is, start from the ground up and make sure the mechanicals are good first. Is the locknut actually tack welded? When there was a locking ring there that they didn't use?
frank8003
4,984
Deuce brakes minor adjustor broke away how to fix
Deuce. Is this factory stuff as seems no TM says how it is originally fastened. It is broken away of top forward minor adjustment bolt/cam. I don't see how it was originally installed and can not figure how to fix it.
I have plan "B" but would like to fix now, while it is apart, for good.
gimpyrobb
dumpsterlandingfromorbit!
27,785
751
Cincy Ohio
Frank, I got your email, but today was LONG. I will see if I can gather up the parts this weekend. Send me a mailing(shipping) addy.
gimpyrobb
27,785
751
Cincy Ohio
Until I get in the hub, I am not sure about this, but they might not be considered "serviceable" parts, as in, the TM might consider that part of the backing plate.
I will let you know once I get in a hub.
frank8003
4,984
This is going to be interesting solution
View attachment RR tandem adjuster.pdf
Would a moderator please put this thread into the Deuce forum please.
I see now I put it in the wrong forum.
RR tandem forward minor brake cam fixture fail.
Fixed it.
The file should work now as it can be viewed maybe with win media player.
This one took some doing as it was assembled before the backing plate was hot riveted to the Rockwell axle. Would have been more difficult to make an external device to pull the spring and cam in so I made internal.
