CCATLETT1984
- 5
- 0
- Saint Clair Shores, MI
Attached it a pic of the Glow Plug that has been stuck in my truck since before i bought it. Someone put a standard GP in and as you can see it both drooped and swelled at the tip. I was able to remove it with a extractor set that i got off of ebay. The set contains a few shims and a nut that is hinged, you thread the gp out of the head as far as you can. Then you put the split nut on it and put in the shims to take up the distance. you turn it out as far as you can, then repeat after adding more shims. It came out nice and steady, you must be carefull to make slow and steady movements so you can feel if the GP is moving still or twisting (as you really dont want to have to pull the head off to get a broken tip).
Here is a link to the tool i used: OTC 6005 Diesel Glow Plug Extractor
http://shortlinks.net/zip721
here is another tool that i found, might be easier to use:
http://jjandaracing.com/en-us/dept_9.html
