it was mounted to that raised strip just to the right of the t-case shifter , i dont remember where the power came in from. the t-case shift lever light power wire is there but is on the light switch. the dome light is right above and gives way more light.interior light, might have been an O/C truck that they needed light on a regular basis to be able to read/write, etc...
Is it hooked up to run just normally? or is it attached to some sensor wires?
