Thoughts on the A/C kit on an M923a2
Steelreaper80
96
Indianapolis IN
Anyone have experience with the A/C kit from TMG? I sleep the cab of my truck when in the field and I sweat my n*t's off because I have to keep the winders up due to mosquitoes . Thoughts?
simp5782
Feo, Fuerte y Formal
9,322
Mason, TN
You can piece an entire ac kit together for under $1000. It's not worth it if they want 2800 for theirs.. Surplus mobile climate control interior units are on Ebay for surplus. 74m35a2 has the engine bracket. the spartan mrap condensor is around $200. Compressor is $100. Having correct length hoses made is the biggest cost $350 for 4 hoses.
74M35A2
313
Livonia, MI
Buddy did a universal under-dash kit in his M923a2 for $500 complete and loves it. Compact and works great. Available in 24v. I don’t like the Humvee evaporator because you essentially lose your back window and center seat. Can’t post links, but I just checked eBay and there is a universal 24v kit for $519 that includes compressor, evaporator, condenser w/fan, receiver/dryer, and all hoses and fittings as well. My 8.3L bracket is under $200, so as Simp said, you would be under $1k and all new. Spend the $1,800 left over on diesel fuel.
My 8.3L bracket kit below. Also shown w/130A alternator. Tell the kit supplier you need an 8 groove pulley on the compressor.
Nomadic
78
Nevada
If you could roll the winder down would that be enough air? What I have done is screen the windows. Cut fiberglass screen from the hardware store to size each window frame with a few extra inches around the window boundary. With the windows rolled up, attach the screen with small round earth magnets around the border. Roll the window down and wah-lah. It would be much quieter than running an A/C if the weather isn't that hot.
th3v3rn
Utah
I saw one here on S/S forsale
I have a condenser that goes in front of the Radiator I would sale. it is new
Yeah, I messaged and emailed him a bit ago. Hopefully he responds.
What size condenser and does it have mounting hardware for an a2?
98G
Former SSG
4,170
Any leads on m939a2 compressor mounts? Can't seem to get any response from any one on here about their mounts.
I've got one. And receiver dryers.
Here are pics of everything AC related that I have -
2 hoses, 2 receiver dryers, and a bracket.
M35A2-AZ
380
Tonopah, AZ
It is for the M939's I do not think it has hardware, I think when I did my trucks I just bent some flat metal and made them. But that was some time back.
  • Like
Reactions: 98G
th3v3rn
Utah
So these don't have fans. I see some kits with fans but if you're moving that should also work.
M35A2-AZ
380
Tonopah, AZ
It uses the truck fan for cooling. You have to replace the fan switch with a elec. one and then wire it into the AC unit, not that big of a deal.
I think I may have a condenser for a Hmmwv that has the fans on it. Looks like this. I little big to ship.
  • Like
Reactions: 98G
