Tire and Wheel question
Olly
Bristol/CT
Just wondering if the 14.00R20s would fit on the stock M818 11.00R20 wheel? Because the recommended wheel width for the 11.00R20 tire is 8 inches and the 14.00R20 is 10 inches would it be that much of an issue?
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
They will work. They wont like it but they will work with the tube anyway. You risk a bead blowout if loaded heavy
Olly
Bristol/CT
Thanks for the quick response
The reason why I was asking was because I saw the dually mrap wheels for a good price and I noticed that they're normally 8 inches wide but normally they have the 12.00R20 on the rear and I don't really want to go smaller than a 49. I also noticed there's a different set of mrap wheels that are aluminum that have the budd bolt pattern and will fit 10" wide like the 49's and 53's its just they were a lot more expensive for a wheel. But if the 8 inch wide wheels will be taking a gamble I'd rather just spend the money on the wider wheels now and just not have to worry. Sometimes a deal isn't exactly a deal but thanks for the heads up.
simp5782
9,339
Mason, TN
The dually MRAP wheel require beveling in order to make them work or changing out the studs to hub pilot type The caiman mrap wheels are more desirable due to that fact they are a budd pattern. they were based off the FMTV type axles/hubs.
4,744
Also be careful looking at MRAP wheels, some have bolt patterns completely incompatible with the 5 tons. They however can be used on a 2.5T with adapter plates, so that's the one upside to those.
