Tire chain puzzle
jimmcld
Denton, Texas
I laid out my tire chains tonight and found that all three of them were either missing a link of had a link loose on one end. The chains are put together with what looks like a big rivet, bent into a "J". I had a couple of extra rivets and an extra link. So, I wondered if there was a way to repair two of the chains with parts from the third. The trick was to try to hook the links into the rivets without having to straighten them our and re-bending them. They reminded me of an old puzzle I have that is over 100 years old. I played with them for the better part of an hour, when all of the sudden, I arrived at the solution. There is a way to take them apart and put them back together!
cranetruck
75
Meadows of Dan, Virginia
Yes, the chains can be modified or fixed, I had a set for duals and changed them into singles when I had 900s on the deuce...
Have been thinking about adding cross links to make them more "hard-pavement-friendly".
Verkstad
Idaho panhandle
That's a great feature of those chains, does not need tools to change a crosslink, Or modify the whole set. I always known that type of swiveling crosslinkchains is intended for mud. But I've got both kinds for a lot of my equipment they work fine either way snow/ice or mud.
Jakob
cranetruck
75
Not to hijack the thread or anything, it it related, kind of, the chains for my 8x8 have "TS type" and "low pressure" in its description, can someone shed some light on that?
The part number is MS500055-30.
