dm22630
- 42
- 0
- Front Royal, VA 22630
I changed the front 2 tires on my deuce with ZERO problems with my impact gun running off the emergency air line on the rear.
So one of my outer rear tires is FLAT....and I went to change it today. 3 lugnuts came right off......3 of the came halfway unscrewed & then unscrewed the lugcaps off the studs. The tire is now off the truck with 3 lugnut/lugcaps still in the holes.
How do I fix this?
I sprayed both sides with PB Blaster, and sprayed the hub with the 3 that stayed with PB Blaster also. So they are soaking as I am writing this.....
Thanks!
How do I fix this?
Thanks!
