Tire Crazy
m816Buch
Morganfield,KY
anybody put g177s on outer duel and left the 900x20 on the inside????? Super singles with automatic duel option....HEHEHEHE...just a thought
Valence
555
Davis County, UT
I'm no expert, but that doesn't seem like a good idea. The 9.00R20's on the inside wouldn't be touching the ground (I assume you meant by "automatic dual" as they could touch the ground when off roading? I wouldn't want the inferior tread). Also G177 11.00R20's are not considered "super singles". Not to mention you would have a strange tire track. See the figure in post #5 by forum member gringeltaube:
http://www.steelsoldiers.com/deuce/43951-flipped-hubs-backing-plate-width.html
The G177's are rated high enough that you can flip the hubs in the rear and run them as singles all the way around the truck. I put G177 11.00R20's on my deuce, but I chose to keep them as duals:
http://www.steelsoldiers.com/showth...e-s-tires-to-Goodyear-G177-11-00R20s-(dualed)
Either option has their pros and cons.
