Tire Leakage
ralphluby
York ME
I have removed most of the CTIS system on my (93) M923. Is it possible to get tire leakage once the system has been removed. I have not yet removed the fitting into the rim and want to do so. Has anyone found the proper pipe plug size?
Suprman
696
Stratford/Connecticut
Usually the wheel seal goes bad from moisture getting in over time and causing rust and corrosion inside. Air up the tire and spray windex or soapy water all around the rim and look for bubbles. A standard schrader valve will screw into the valve stem once you take off the ctis hose.
ralphluby
York ME
Thanks for your comments. Unable to upload a picture at the moment. The fitting goes into the hub, not the wheel and was part of the CTIS. I have replaced the "O" ring the rim but still have a very slow leak in the tire and have bubble tested it without any problem.
Suprman
696
Tire air cannot leak out the hub connection. Spray all around front and back including around the tire stem. A new o ring does no good if there was corrosion inside. You have to sand and rust prime then help it with a little rtv when putting the new o ring in and the wheel back together. Dont air up for 24hrs.
Special T
21
Wetside/ WA
As much work as it may be... take the tire and wheel off and set it flat on the ground mix hot water and liquid soap with a reasonable ammount to help detect the leak. Pour/spray the mix anywhere where the tire wheel come together or places that must seal. If nothing is easily seen let is sit and come back. Foamy bubbles will help point out the leak. Since we cannot see the wheel type you may need to flip the tire/wheel over and apply to the opposite side if do not detect a leak. When you tightened the combat wheel did you use the same method you use when tighting lug nuts? 12,6,3,9, oclock? When doing hummer wheels I often just tighten all snug then toque down from there to keep the o ring from squiring out.
