Tire pickup from Chambersburg delivered to Nassau County Long Island, NY
NY Tom
848
Riverhead, NY
Purchased 6 deuce tires likely loaded on 2 skids at Chambersburg.
I will probably make the trip to get them but figured it might be worth asking if anyone else is picking up anything there and bringing it back to Nassau County?
Maybe my stuff can hitch a ride along for a reasonable price.
Have a loading dock, forklift, pallet jacks etc. available at drop-off location.
reset2
100
Myersville MD
How did the load out go. Were you happy with the tires?
Pickup at warehouse or field?
Sent from my SM-G935V using Tapatalk
NY Tom
848
Riverhead, NY
I used a shipping guy I found thru the service that Govplanet has. It worked out OK. Wasn't cheap but saved me the trip over there. They tack on a pretty good charge for their services but once you find a guy you can avoid all that.
Guys name is Blaise. 615-389-4590. Best price I could easily find. Sets up loads for all kinds of stuff coming out of these surplus location.
Tires were good can't complain. Four out of 6 were new tires on what looked like new rims. All of them held air. Two of them had water in them but no big deal.
fasttruck
638
Mesa, AZ
If they have water in them that implies they were flat and somebody put enough air in them to get out the door.
NY Tom
848
Riverhead, NY
Might be the case. All the tires were deflated when I recieved them. Personally I think they were left out in the rain this way and water sits on the rim and gets in the split area.
I am by means no expert on this.
Truck came with a bunch of crappy spares when I bought it. Most were deflated and probably 4 had water in them. So far every tire I inflated slowly, water was forced out, and they stayed full for over a year since. Pretty sure that there will be moisture trapped in them still which is bad but maybe not as bad as being full of water.
I store them inflated standing up covered with a tarp outside. Good ones in the shed. If I have to leave any uncovered I leave them standing up so the water doesn't really have anywhere to pool. Also I try to leave the valve stem on the top.
fasttruck
638
Mesa, AZ
If there has been a lot of water in the tire/rim the problem will surface when you go to dismount the tire. This because a ridge of rust will form on the rim under the lock ring. This in turn makes it difficult to drive the bead of the tire down far enough to get the lock ring off. And once the lock ring is finally out of the way the next problem will be to get the tire and tube to separate from the rim. Tire shops have a basket like devise to elevate the tire off the floor so you can beat it down with a hammer.
NY Tom
848
Riverhead, NY
Thank you for this information. I have not yet tried to break down one of these tires. I have the tools and hopefully an old timer neighbor can help me and give out some pointers.
Based on the way the spare rims I received were rusted I figure they will be a very hard time to break down and maybe just scrap at this point. Was happy to see these surplus rims looked to be in good shape.
