Tire Questions
CapHap
Greenbrier,Arkansas
Hey guys. My 818 is running 12.00 20's right now. The steers are starting to wear pretty bad, I found some 14.00 20's but can I still run duals with the 14.00's? Or will they rub? Anybody made a spacer for the rear or put in longer wheel studs? I like the taller tire but don't want to sacrifice my rear duals.
73m819
325
gainesville, ga.
NO, will NOT WORK, will rub BAD on the inside, REQUIRES SPACERS and SPECIAL studs with both the front and rears to use, will be OVER WIDTH by about a foot, the tire WILL stick out past the fuel tanks, also will make the hole between 3rd and 4th a lot deeper.
In another words, NOT A GOOD IDEA, I was going to do this on the M819 (OE 1200s) for your same reasons, did not happen because of the above reasons.
