Tire rack boom uses
Ddmk18
James Creek PA
Not that it's recommended but in a pinch I used it to load a mt654cr transmission. I have further plans to mount a bearing in where the two pieces bolt together so I can use it to load the future bed.photo 1.jpgphoto 2.jpg
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
No need to waste good money on a bearing. I had some 2" round solid bar about 3ft long. Take off the top and drop in the round, grease the crap out of everything, good to go. Heavy wall tube might work too.
Castle Bravo
Hundredaire Socialite
225
Arizona
The ones on the A1 and A2 trucks are beefier than the A0 trucks, but even lifting a 1400R20 tire with the A2 davit seemed kinda sketchy to me. I stood well away from it. As far as when it will get damaged, I have no idea.
gimpyrobb
27,785
749
Cincy Ohio
Jesse, I've had a 395 on a Hemtt rim on the end of mine. Thats about 350 or so lbs. The assembly could easily handle more, but my deuce bed was flexing a bit. I would assume in its stock mount you could do up to 750, but your getting up there, especially if you have the tube extended!
mkcoen
381
Spring Branch, TX
Mine's missing the hoist so I splurged today and got a China Harbor Freight ratcheting tie-down rated at 3000#. I figure the short end around the I-bolt on the slider and then loop it around the tire and ratchet it down. Not as fast as a chain hoist but then I don't expect to be trying to change the tire while taking sniper fire so can take my time (if, for some reason, I am taking fire then screw changing the tire it'll suddenly become a "run-flat").
Ddmk18
James Creek PA
Well the transmission came in at 844lbs on the skid. So I carried the skid about half a block to get it to my house and I estimate it weighed about 40lbs. I though the tire davit handled it well. Had a little bow to it but I wouldn't be afraid of it snapping at that weight.
