What is "sipping"?Has anyone tried siping their 395/85R20 to improve its performance on the rainy days on the highway?
BINGO at that is key to longevity "if" you drive a lot.....but it also can help cool down a tire....
True.... but you have to be real hard core.. aka...... crawling by spinning screeching tires that occasionally grab some traction when they find a small thing to bite on (or rip a lug off).If you are hard Offroad on your tires, you can also lose chucks of tread easier. Or so I have heard.
It can be for sure depending on the driver and his skills in wheeling, especially on the rock. Unlike mudding, rock crawling is "not" about speed, it is all about finesse. One has to keep the wheel speed down to avoid wheel spinning. One airs down the tires to the point the tire surface molded into the shape of the rock. Let the vehicle crawls up slowly. If you are heavy on the gas, things will start to break.If you are hard Offroad on your tires, you can also lose chucks of tread easier. Or so I have heard.
Tire groovers are found on ebay with all types of blades. Just buy small ones for what this thread relates toLast time I looked into siping smaller tires, I could not find anyone locally that still did that.
Where are you guys finding g someone to do it?
For siping, I just use my Dremel with a cut-off wheel. I made a jig, so siping will look more consistent through out the tire. It is not too bad. For what I need, siping is fine, I don't need grooving.Last time I looked into siping smaller tires, I could not find anyone locally that still did that.
seems to be only one left that will sipe tires and that is Les Schwab and Commercial tire. Had to search hard to find a place in my home town in OH. they are out there.... you just got to combine net search with good ol' call around.. ask for recommendations etc. (ps that part didn't help much.... lot of tires stores just said "no one did it" with a response tone of... "who is this idiot".... just kept calling anyway. btw.... they may say can only sipe tires based on wear depth. too much wear depth limits them liability wise the store said. though I suspect it is more about selling new tires.Last time I looked into siping smaller tires, I could not find anyone locally that still did that.
Do you have any picts?For siping, I just use my Dremel with a cut-off wheel. I made a jig, so siping will look more consistent through out the tire. It is not too bad. For what I need, siping is fine, I don't need grooving.
I knew a UPS feeder driver (semi driver) and has to go over 2 passes to get to the hub. He swore by siping. With 2 passes each way he may need to chain up and then take the chain off over each pass as needed. He said that with sipped tires he didn't need to chain up as often.Funny this thread should pop up today. I was eyeballing my tires after a short ride yesterday. Best way to enhance traction on a tire you own already. Have spent a bunch of time researching the pros and cons. Seems like there isn’t much in the way of negatives. Summit used to sell a tire siping tool, haven’t checked of late on the availability.
