sermis
- 17
- 38
- Temple, TX
OK, I went to super singles on the deuce. I took a stock rim and added 3” to the outside of the rim to make a 10” rim. Spin balanced the rims and added weight, steel plate welded to the rim, to balance the rim. I Mounted Michelin 15.5 / 20’s with heavy tube and flap on the rims. Ran one wheel on the balancer and it is 24 to 30 ounces out of balance. Driving down the road you can really tell it is out of balance. I was thinking about Dyna Bead or Counter Act ceramic balance beads. Not sure it they will work being that far out of balance. I was talking to an old tire guy that suggested adding a quart of antifreeze to each tire. The principal of the beads is to distribute around the tire and load up where the weight for balance is needed. Drop back down on stop and then redistribute when you are moving again. Wouldn’t the liquid do the same thing? A lot cheaper than the beads.
