Tire /wheel question
ccf460
granite falls/N.C.
I searched, but couldn't find an answer, so......
Has anyone put 11.00R20 G177's on the 10" x 20" bolt together 5 ton combat wheels?
I like the look and safety of the bolt together rim, and the bead lock feature.But want the G177's for durability.
dmetalmiki
2,028
London England
Within that range you should easily be good to go. We have 1200x20 on 900x20 stock rims no problem.And the wrecker takes 1100 or 1200 standard.
tobyS
833
IN
Will you run singles then on a 5 ton with the G177?
ccf460
granite falls/N.C.
I was trying to find recommended minimum and maximum rim widths for the g177's, but no luck. Also wondering if the bead thickness will work with the rubber bead lock inserts.
These are going on a ford F700, singled.
tobyS
833
IN
Does the F700 have 10 lug? My F600 (4 x 4) has 6 lug. I used M105 trailer tires/wheels to give it new shoes. The G177 is radial and (I think) can be used tubeless...and without bead-lock if your staying on the road and keep higher pressure.
I don't see a problem with an 11" tire on a 10" wide rim, but am no expert. Have you looked into 12.00 or is the availability of 11.00 G177, the driving consideration?
ccf460
granite falls/N.C.
My F700 is a 1995 crew cab with a p pump 12 valve cummins. It is a 10 lug. I currently have the combat wheels in question on the truck with 15.50's on it, cool but not a smooth highway speed ride.
tobyS
833
IN
Okay, got it. Do you have any pictures?
11.00 is a lot smaller tire and would help with the bounce. I bet the Goodyear specs on that tire will tell you the max rim width. Beads would both be "industrial" so should work.
What do you consider highway speed for your application? Have you checked the speed rating of the G177?
red
25
Eagle Mountain/Utah
G177's aren't speed rated (labeled) because they are an over the road tire, highway speeds are not a problem for them. They are a tubeless radial.
Might be a challenge to seat the beads unless you run a beadlock insert.
Special T
21
Wetside/ WA
An 1100R20 is only rated for a rim width of 7.5-8" you may be able to stretch the width another .5" for light duty use. 10" is way to wide and will change the flex point too much.
simp5782
Feo, Fuerte y Formal
9,369
Mason, TN
You can run a G177 in an emergency on a 5ton combat wheel. It will bead up. A tube type tire can go on a tubeless wheel. It does not hurt it. If you do it in an emergency i recommend putting it on the intermediate axle so it does not have alot of weight on it empty.
Sent from my SM-G860P using Tapatalk
