tires and rim question
pinwormfood
easton, pa
fellas, i have a m1009 with a 4 inch lift (leaf in front and shackle flip rear), and stock rims and tires. I'd like to up my tire size to 35 inch. if I have a 8 inch wide rim (stock size is 8 inch, right?) can i put on a set of 35-12.5-15? will that screw up the bead? is that too much witdh for that rim? i just want someone that knows if I can do it. it's so frustrating. everyone had differeing opinion on this one...i just would like a definitive yes or no. lol. thanks guys.
and if i should not do this, is there a 16 inch rim that GM made that looks like the stock steel rims like on the 1009? and if i go to a 16 is there any benefit?
I hate not being able to figure this out. thanks for the help guys.
pinworm
11Echo
92
CT W. R.
pinworm
I've been running 33/12.50 tires on GM 8" wheels for almost 40 years with no problems. Remember as you go up in tire diameter that the M1009 has 3.08 gearsets in the axle's stock configuration.
BigRix
Tucson, AZ
Mine is running 35x13.50R15 Baja Claws.
This the one Rally rim that is on the truck but it is the same size as the stock CUCV rim.
pinwormfood
easton, pa
pardon my ignorance...but a 3.08 gearset will still be ok on a 35...right? i'm not beating the **** out of it, but on the flip side of that, will i lose low end torque or high end top speed?
thanks, pinworm
Cleptomaniac
Tecumseh ,OK
Lol their isnt much low end tork! And when you put 35s on it is all gone! That being said I have 35-12.5-15 on mine and it gets around fine. Just don't expect to do any burn outs! ;-)
Oh yea they look great also!!!
BigRix
Tucson, AZ
I just went the other direction and couldn't be happier.
Went from 35x13.50R15 Baja Claws on stock wheels to 32x11.50R15 BFG AT KO's on alluminium wheels and it is like a new car. Accelerates faster, speedometer is more accurate, and best of allot rides smoooooth.
Best of all when I lower it down they will clear without much problem.
Doesn't have "The Look" anymore, but that's ok with me.
ImageUploadedByTapatalk1343432419.499354.jpgImageUploadedByTapatalk1343432432.516586.jpg
HOWEY
ireland
gear ratio
So what gear ratio would be an acceptable compromise if a guy was running 35s and used it primarily on the road?
