TM For M1078A1 trouble shooting Ele?
engele
Nagold / Germany
Hi together,
i need your help!
I'm looking for a tm for my M1078A1. I can find only the older m1078.
The charging Symbol lights, and the Voltmeter is only at 20-22v. Think the alternator or the Regulator is damaged. I think they Bridged/shorted them wrong as the Battery box was empty. There is a small burnt y cable from the negative pole.
Hope someone can help me.
best regards Alex.
porkysplace
1,491
mid- michigan
Any source for parts and service manuals for the M1078A1?
m1078_TM 9-2320-365-10.pdf
m1078_TM 9-2320-365-10 for the M1078 series trucks.
m1078_TM 9-2320-365-20-1.pdf
m1078_TM 9-2320-365-20-1 for the M1078 series trucks.
m1078_TM 9-2320-365-20-2.pdf
m1078_TM 9-2320-365-20-2 for the M1078 series trucks.
m1078_TM 9-2320-365-20-3.pdf
m1078_TM 9-2320-365-20-3 for the M1078 series trucks.
m1078_TM 9-2320-365-20-4.pdf
m1078_TM 9-2320-365-20-4 for the M1078 series trucks.
m1078_TM 9-2320-365-20-5.pdf
m1078_TM 9-2320-365-20-5 for the M1078 series trucks.
m1078_TM 9-2320-365-24P.pdf
m1078_TM 9-2320-365-24P for the M1078 series trucks.
m1078_TM 9-2320-365-34-1.pdf
m1078_TM 9-2320-365-34-1 for the M1078 series trucks.
m1078_TM 9-2320-365-34-2.pdf
m1078_TM 9-2320-365-34-2 for the M1078 series trucks.
TM's ending with a " P " are parts manuals , the rest are service manuals.
awind
Saranac, NY
Thanks but we already have these.
I and the original poster are looking for the A1 TM's especially. Thanks.
awind
Saranac, NY
I do have the operators manual for the A1 and as I understand starting with the A1's the TM were incorporated in some sort of computer sytsem and not in paper or pdf form. Let me know if you want the operators manual.
Suprman
694
Stratford/Connecticut
I looked on the discs I didnt see any tms. I believe in the diag program it has troubleshooting steps. As computerized as the truck is, maybe paper manuals just dont work. I have spoken with army techs they say first thing they do is plug in the laptop and run diagnostics. My first gen truck uses the older round ste ice interface plug so I havent been able
to play with it.
Lmtv772
Banned
651
Florida
I thought to have read somewhere that there are fusible links between alternator and wires? Not sure anymore.
awind
Saranac, NY
Battery Tray area Wiring
Looking for help in the wiring of my battery box area. I completely disassembled my battery tray and disconnect and unfortunately some of my wiring labels came off. I could use some help in determining where the long small white wire connects from coming in the front of the battery box. Not sure if that is to be 12V or 24V. Also the 3 large cable that connect to the disconnect. Not sure if the 2 wires together are 12v or 24v.
