TM part location
ohiohmmwv
Columbiana, Ohio
I've been searching the TM for the small aluminum channel and bolts that cover up the bundle of wires from the rear lights. It's down in the body below the rear tail lights. Anyone know what page that's on?
Sent from my iPhone using Tapatalk Pro
1 Patriot-of-many
86
Zimmerman MN
Good question, The closest I came was a bracket that attaches to the top of the fender inside the 1rst Parts TM. I'll see if I can't see a P/N on either of them later. Just got done trying to ground one of my antennas missing a ground strap when I got it, finally found a screw with the right threading, then of course the screw is too long. Story of my life.
Retiredwarhorses
4,170
Brentwood, Calif
You need to know if you have the new or old "D" beam installed...the new trucks have a thicker "D" beam.
so there 2 styles of wire guards, old and new.
ohiohmmwv
Columbiana, Ohio
Actually I'm not sure if it's just the PDF I have or something else. My TM doesn't find that part number. I only need to know the screws and bolts and wire loop parts. I actually have the aluminum boxed shape piece. Just trying to replace all the rusty hardware. Anyone know what Figure number it's under in the TM?
juanprado
2,898
Metairie/La (N'awlins)
look in the 280 series; 24p, part 1, figure 88, item 48
I just used the search function in adobe. I don't know the updated part number RWH referenced so I don't know if it is the 387 series?
