MAGNUSBULLETS
- 1
- 1
- ARDMORE, AL
I have a 4000 lb forklift built in 1989 by Defense technology, very similar to other 4000 lb ones, A couple of members have been nice enopugh to upload some TM for me. Mine has air over hydraulic brakes, others are all hydraulic. Mine has no master cylinder like others, ;air chamber is mounted on driver wall next to the left shoulder. with a master cyleder mounted on the engine side of that partiion. The master cylinder has no resevoir, has some type of gauge, with two wires attached, like a secsor. we traced the line the unit of device that the shifter is ,mounted to at the drivers hip, Has a line that t"s off the shifter area that goes down to the brake lines that run to the front brake units. Lools like it uses trans fluid to operate the braked and not dot fluid. Any help would be apreciated. Same engine as othes, just like other 4000 lb units, my radiator stands straight up not slanted Thanks
