Asmoday
- 0
- 16
- Los Angeles, CA
Well,
I decided to change the hoses, thermostat and give a vinegar flush to my newly acquired M1009. Normally this would be an easy job...normally. Well not today...
It stated out with the bolts on the thermostat housing being seized and I mean really f'in seized. I soaked and soaked the bolts in Aerokroil but finally I had to give it a shot trying to remove them... squeal squeal squeal....!
They did come out with quite a bit of force but in the end they brought with them a couple of threads.
The next issue was after I had to hammer the housing neck to break it free...the remaining gasket material was an absolute nightmare to remove. It took me hours and hours with many razor blades to finally get all the gasket material off. ****, I tried soaking the gasket material with every solvent known to man...Acetone, brake cleaner, mineral spirits, MEK, etc. etc. you name it and in the end it was Kroil penetrating oil and lots of razor blades to get all the gasket material off.
I chased the bolt threads with a die and chased the threads in the mounting face with a tap...very very carefully. Everything cleaned up nice and went back torquing together fine. I used Hylomar sealer and anti-seize on the bolts...
I really think the thermostat was original and has never been replaced as the gasket material really had twenty five years of hardness...! The GM thermostat I pulled out definitely looked like it had 66,000 miles...LOL.
The vinegar/distilled water mix is in right now and I will drive it a couple of hours tomorrow and then drain, rinse, rinse and then fill with 50/50 mix. It's gonna need a radiator in the next year or so.
Below are a couple of pics during the clean and tap. In the pic with the tap threaded in I had already spent 4 hours trying to get gasket material off...no joke....
