TOOL Kit Organization Maintenance CUCV
Craig C
San Jose, CA
Here is the front page from a list of tools for the CUCVs. Is there one on line somewhere or does anyone one have one. I was given a number of tools from this set and the front page which as you can see isn't in very good shape.
Thanks,
Stonepicker1
109
Coconut Creek, Florida
I looked up the NSN: 5180-01-156-0466, Tool Kit, General Mechanic's.
It shows the component of this kit are: 16 items.
WRENCH WHEEL BEARING 5120-01-180-0558 1EA, PULLER PITMAN ARM 5120-01-179-1318 1EA, HANDLE DRIVER 5120-00-677-2259 1EA, WRENCH SIGNAL SWITCH 4910-01-179-6341 1EA, INSTALLER NEEDLE BEARING 5120-01-169-4878 1EA, COMPRESSOR LOCK PLATE 4910-01-180-6155 1EA, INSTALLER AXLE SHAFT BEARING 5120-01-170-3279 1EA,SENDING UNIT FUEL 4910-01-179-6340 1EA,INSTALLER REMOVER WHEEL BEARING 5120-01-179-1034 1EA, REMOVER RETAINING CLIP 4910-01-179-2518 1EA, INSTALLER PUMP PULLEY 4910-01-179-2517 1EA, WRENCH WHEEL BEARING NUT 5120-01-170-0628 1EA, INSTALLER AXLE SEAL 4910-01-179-2516 1EA, REMOVER PUMP PULLEY 4910-01-181-1959 1EA, BIT SET TORX 5120-01-178-6342 1EA, WRENCH WHEEL BEARING NUT 5120-01-170-6664 1EA
