Tool outfit,pioneer m353
NEIOWA
126
NE IOWA
I'm looking for TM or component list Set Kit Outfit for TOOL OUTFIT,PIONEER on the M353 trailer NSN of 5180-01-355-4344
These have a generator (and perhaps also air/hydraulic pump). Several big plastic case for tools/equipment.
Anyone have idea?
Stonepicker1
77
Coconut Creek, Florida
[FONT=Arial, Helvetica, sans-serif]5180-95-E23[/FONT]
[FONT=Arial, Helvetica, sans-serif]SETS, KITS and OUTFITS[/FONT]
[FONT=Arial, Helvetica, sans-serif]SETS, KITS, AND OUTFITS FOR TOOL OUTFIT PIONEER, PORTABLE HYDRAULIC AND ELECTRIC POWERED TOOLS TAILER MOUNTED[/FONT]
[FONT=Arial, Helvetica, sans-serif]5180-01-355-4344[/FONT]
[FONT=Arial, Helvetica, sans-serif](LIN W58486) [/FONT]
[FONT=Arial, Helvetica, sans-serif]EIC YX6[/FONT]
[FONT=Arial, Helvetica, sans-serif]THIS PUBLICATION SUPERSEDES ALL PREVIOUS RELEASES[/FONT][FONT=Arial, Helvetica, sans-serif][/FONT]
[FONT=Arial, Helvetica, sans-serif]HEADQUARTERS, DEPARTMENT OF THE ARMY[/FONT]
[FONT=Arial, Helvetica, sans-serif]02 MARCH 1999[/FONT]
[FONT=Arial, Helvetica, sans-serif]DISTRIBUTION STATEMENT A: APPROVED FOR PUBLIC RELEASE, DISTRIBUTION UNLIMITED[/FONT]
tcody
Illinois
Should have the following: Stanley hydraulic pump and hoses, hydraulic electric 3KW generator, small medium and large electric drills, grounding wire, hydraulic chain saw, hydraulic concrete saw, hydraulic drill and impact wrench, two electric dewalt grinders, two dewalt electric saws, four 50 foot electric extension cords, misc grinding wheels and wire wheels, and a tool box with impact wrenches etc. The power unit is made by Hydraulic Technologies Inc. and parts are still available. The Lister-petter engine is pretty nice. The TM number is TM 5-1730-245-14
manuals are available for free download in pdf format from LOGSA.
TM 9-2330-247-14&P
TM 9-6115-646-14&P
TM 9-6115-647-14&P
I got this from an earlier post. Can't remember where I got the info, but when I get home I will try to confirm it is accurate.
Cheers,
Cody
tcody
Illinois
NEIOWA, I couldn't find the reference I used for that info so I can't be certain it is complete, but PM me if you have and specific questions and I can forward my phone number so I can help with your HETO. You are welcome to come by and visit too - we are just outside the Quad Cities.
CARNAC
The Envelope Please.
644
Corpus Christi, TX
COMPONENT HAND RECEIPT:
END ITEM STOCK NUMBER: 5180-01-355-4344
END ITEM DESCRIPTION: SETS, KITS, AND OUTFITS FOR TOOL OUTFIT PIONEER, PORTABLE HYDRAULIC AND ELECTRIC POWERED TOOLS TAILER MOUNTED
PUB NUMBER: 5180-95-E23
DATE OF LAST REVIEW: 01 APRIL 2014
SC 9999-01-SKO PUB DATE: 01 APRIL 2014
LINE ITEM NUMBER: W58486
5180-01-355-4344
Picture Not Available A
TOOL OUTFIT PIONEER, FOR PIONEER AND CONSTRUCTION WORK SC 5180-97-E23 (LINW58486) (WT: 76200 CU; 816000) 94335,
N U SE
5120-00-227-8088
SETS, KITS, AND OUTFITS FOR TOOL OUTFIT PIONEER, PORTABLE HYDRAULIC AND ELECTRIC POWERED TOOLS TAILER MOUNTED B
ADAPTER,SOCKET WREN, 1/2 IN SQ EXT END, 3/4 IN SQ INTERNAL END, 2-1/8 IN O/A LG:1-1/2 IN O/A DIA,
X U EA 1
4210-00-289-1305
Picture Not Available B
ADAPTER,STRAIGHT,PI, 2-1/2 IN MALE NPT X 2-1/2 IN MALE HOSE THREAD (NH); HEXAGON HOSE NIPPLE; COPPER ALLOY MATERIAL; USED W/PUMP UNIT, CENTRIFUGAL NSN: 4320-01-086-2873,
X U EA 1
5133-00-360-2734
BIT,AUGER, SCREW PT; HOLLOW CENTER; FLATTED RD SHANK; 1 IN DIA, 14-3/4 IN NOM LG,
D U EA 3
5133-00-360-2733
BIT,AUGER, SCREW PT; HOLLOW CENTER; FLATTED RD SHANK; 3/4 IN DIA, 32-5/8 IN NOM LG,
D M EA 3
5133-00-360-2730
BIT,AUGER, SCREW PT; HOLLOW CENTER; FLATTED SHANK; 7/16 IN DIA, 14-1/4 IN NOM LG,
X U EA 3
5133-00-360-2737
BIT,AUGER, SCREW PT; HOLLOW CENTER; MORSE TAPER SHANK 2; 2 IN DIA, 32-15/16 IN LG,
D M EA 1
5133-00-541-3751
BIT,AUGER, SCREW PT; HOLLOW CENTER; FLATTED RD SHANK; 1 IN DIA, 32-3/4 IN NOM LG,
D U EA 1
5133-00-360-2731
BIT,AUGER, SCREW PT; HOLLOW CENTER; FLATTED RD SHANK; 7/16 IN DIA, 32-1/4 IN NOM LG,
X U EA 3
5133-00-360-2732
BIT,AUGER, SCREW PT; HOLLOW CENTER; FLATTED RD SHANK; 3/4 IN DIA, 14-5/8 IN NOM LG,
D M EA 3
3230-00-954-7970
BLADE,CIRCULAR SAW,, COMBINATION/RIP, 5/8 IN ROUND ARBOR, 8-1/4 IN NOM DIA;40 TEETH,
X U EA 3
2540-01-389-3172
BOX,ACCESSORIES STO, BODY 1/8 IN THK STEEL; LIDS 1/8 IN THK INLAND 4 WAY SAFETY PLATE (OR EQUIV); ROAD SIDED BOXES W/OA DIM 127 IN LG X 25-1/4 IN WD X 12 IN HGT; MOUNTED ON FRAME ASSY; TAIL, STOP, TURN AND REFLECTOR LIGHTS INCORPORATED; W/STRAPS AND FOOTMAN LOOPS; LIDS W/LATCHES,
X U EA 1
2540-01-389-3126
BOX,ACCESSORIES STOWAGE, BODY 1/8 IN THK STEEL; LIDS 1/8 IN THK INLAND 4 WAY SAFETY PLATE (OR EQUIV); CURB SIDE BOXESW/OA DIM 127 IN LG X 25-1/4 IN WD X IN HGT; MOUNTED ON FRAME ASSY; TAIL, STOP, TURN AND REFLECTOR LIGHTS INCORPORATED; W/STRAPS AND FOOTMAN LOOPS; LIDS W/LATCHES,
X U EA 1
5130-00-293-2858
BRUSH,WIRE,ROTARY C, E1 THREADED ARBOR HOLE;5 IN OD; 1-5/8 IN TRIM LG; 0.0204 IN WIRE DIA; 5/8 IN SCREW THD DIA; 11 SCREW THRDS PER IN; 3500 WIRE POINTS; 5500 RPM SPEED,
X U EA 4
6150-00-682-3460
CABLE ASSEMBLY,POWE, 3 CONDUCTOR; 600 V, N0 12 AWG, PRIMARY INSULATION NATURAL RUBBER ALL CONDUCTOR, PER (81348) J-C-580, TERMINATIONS 2 POLE ,3 WIRE, 15 AMP, 125 V, 1ST END CONNECTOR PLUG, PER (81348 (81348) W-C-596/13, DASH NO. 3, 2ND END CONNECTOR CABLE OUTLET, PER W-C-596/14, DASH NO. 2, 50 FT LG,
X U EA 3
6150-01-022-6004
CABLE ASSEMBLY,POWE, 3 CONDUCTOR; 300V; NO. 14 AWG, 15 AMPS; THERMOPLASTIC JACKET, RESIST WEATHER EXTREME, FLEXIBLE PER (81348) J-C-580; SJE TYPE; W/CONNECTOR PLUG AND CONNECTOR CABLE OUTLET ON OTHER END; 25 FT LG,
X U EA 2
7240-01-337-5269
CAN,MILITARY, 5 GAL; PLASTIC; OLIVE DRAB,
X U EA 2
5340-01-366-3341
CAP,PROTECTIVE,DUST, PLASTIC, USED IN PROTECTING HYDRAULIC COUPLING NIPPLE,
X U EA 9
5340-01-366-3343
CAP-PLUG,PROTECTIVE, PLASTIC, USED IN PROTECTING HYDRAULIC COUPLING BODY,
X U EA 9
2330-00-542-2831
CHASSIS TRL GP M353, M353; 3-1/2 TON; WHEELED TYPE; 188 IN LG X 97-1/2 IN W/O/A DIA; AIR-HYDRAULIC BRAKE; LEG SUPPORTTYPE; TRUNION AXLE SUPPORT TYPE; 108-3/4 IN LG X 44-1/4 IN W/ACCOMADATION; MODIFIED PER US ARMY BELVOIR RDT&E CENTER (97403) DWG 13229E9763 (LINE ITEM NO. E02670),
N U EA 1
3460-00-268-9220
CHUCK, DRILL( 3 JAW K, STEEL; HEAVY DUTY; BALL BEARING; 3 JAW KEY; NO. 2 AMERICAN STD TAPER; 0 THROUGH 1/2 IN; W/KEY,
X U EA 1
5130-00-541-3848
CHUCK,WOOD BIT, MORSE TAPER SHANK NO. 3 DRIVE; 1/2 IN RD SHANK BIT; W/ 1 EA KEY, SOCKET HEAD SCREW, 5/16 IN,
D M EA 1
4730-01-348-0975
COUPLING ASSEMBLY,Q, 2500 PSI MAX OPERATING PRESSURE; PUSH-PULL; 3/8 IN FLUSH FACE VALVING COUPLER SET (1/2 IN FEMALE PIPE PORT) INTERNAL PIPE; STEEL; 2-3/4 IN NOM O/A LG EA PC; SEALS, BUNAN IN FEMALE AND URETHANE ON MALE COUPLER,
X U AY 2
4730-00-995-9578
COUPLING,PIPE, 1/2 -14 NPT FEMALE 1ST END, 1/2-14 NPT FEMALE SWIVEL 2ND END; 1.500 IN NOM O/A LG; CADIUM OR ZINC PLATED,
X U EA 2
4730-01-268-2409
COUPLING,PIPE, 3/4-14 NPT FEMALE 1ST END; 3/4-14 NPT FEMALE SWIVEL 2ND END; 1.625 IN NOM O/A LG; CADIUM OR ZINC PLATED,
X U EA 2
4730-00-958-0384
COUPLING,PIPE, 3/4-14 NPT MALE 1ST END, 3/4-14 NPT FEMALE SWIVEL 2ND END, 2.040 IN NOM O/A LG; CADIUM OR ZINC PLATED,
X U EA 2
5345-00-881-7856
DISK ABRASIVE, UNMOUNTED; CLOSED COATING; PLAIN, FLAT; VULCANIZED FIBER BACKING; 7 IN DIA; 7/8 IN DIA ARBOR HOLE ALUMINUM OXIDE; GRADE 3/0; GRIT 120,
X U BX 18
5345-00-196-1692
DISK,ABRASIVE, UNMOUNTED; CLOSED COATING; PLAIN FLAT; VULCANIZED FIBER BACKING; 7 IN DIA; 7/8 IN DIA ARBOR HOLE ALUMINUM OXIDE; GRADE 1/2; GRIT 36,
X U EA 12
5345-00-196-1698
DISKXABRASIVE, UNMOUNTED; CLOSED COATING; PLAIN, FLAT; VULCANIZED FIBER BACKING; 7 IN DIA ARBOR HOLE ALUMINUM OXIDE; GRADE 1/0; GRIT 80,
X U BX 1
5120-00-224-8950
DRIFT,DRILL, PLAIN; NO. 3 MORSE TAPER SOCKET; 6-5/8 TO 7-1/2 IN,
X U EA 1
5130-01-087-6828
DRILL 115V 25-60HZ, AC/DC; 115V, 3/4 IN SIZE, NO. 3 MORSE TAPER SOCKET, HEAVY DUTY; STRAIGHT DRIVE; 50-500 RPM NO LOAD SPEED; SPACE HANDLE CONFIGURATION,
D M EA 1
5133-00-293-0983
DRILL SE TWIST 29COMP, HSS, STRAIGHT RD SHANK, RH CUT, W/CASE, FRACTIONAL SERIES CONSISTING OF:,
X M SE 1
5133-00-227-9674
SETS, KITS, AND OUTFITS FOR TOOL OUTFIT PIONEER, PORTABLE HYDRAULIC AND ELECTRIC POWERED TOOLS TAILER MOUNTED C
DRILL,TWIST, HSS, 31/64 IN CUTTING DIA, 5-7/8 IN LG, STRAIGHT RD SHANK, RH CUT, NOTCHED PT, 2 FLUTES,
X U PG 1
5133-00-243-9611
DRILL,TWIST, HSS, 15/64 IN CUTTING DIA, 3-7/8 IN LG, STRAIGHT RD SHANK, RH CUT, NOTCHED PT, 2 FLUTES,
X U DZ 1
5133-00-243-9613
DRILL,TWIST, HSS, 21/64 IN CUTTING DIA, 4-5/8 IN LG, STRAIGHT RD SHANK, RH CUT, NOTCHED PT, 2 FLUTES,
X U DZ 1
5133-00-227-9649
DRILL,TWIST, HHS, 7/64 IN CUTTING DIA, 2-5/8 IN LG, STRAIGHT RD SHANK, RH CUT, NOTCHED PT, 2 FLUTES,
X U DZ 1
5133-00-227-9651
DRILL,TWIST, HSS, 9/64 IN CUTTING DIA, 2-7/8 IN LG, STRAIGHT RD SHANK, RH CUT, NOTCHED PT, 2 FLUTES,
X U DZ 1
5133-00-227-9667
DRILL,TWIST, HSS, 25/64 IN CUTTING DIA, 5-1/8 IN LG, STRAIGHT RD SHANK, RH CUT, NOTCHED PT, 2 FLUTES,
X U PG 1
5133-00-227-9660
DRILL,TWIST, HSS, 9/32 IN CUTTING DIA, 4-1/2 IN LG, STRAIGHT RD SHANK, RH CUT, NOTCHED PT, 2 FLUTES,
X U DZ 1
5133-00-227-9647
DRILL,TWIST, HSS, 5/64 IN CUTTING DIA, 2 IN LG, STRAIGHT RD SHANK, RH CUT, NOTCHED PT, 2 FLUTES,
X U DZ 1
5133-00-227-9670
DRILL,TWIST, HSS, STRAIGHT RD SHANK, RH CUT, 7/16 IN CUTTING DIA, 5-1/2 IN LG, NOTCHED PT, 2 FLUTES,
X U PG 1
5133-00-227-9665
DRILL,TWIST, HSS, STRAIGHT RD SHANK, RH CUT, 23/64 IN CUTTING DIA, 4-7/8 IN LG, NOTCHED PT, 2 FLUKES,
X U DZ 1
5133-00-227-9668
DRILL,TWIST, HSS, STRAIGHT RD SHANK, RH CUT, 13/32 IN CUTTING DIA, 5-1/4 IN LG, NOTCHED PT, 2 FLUKES,
X U PG 1
5133-00-227-9654
DRILL,TWIST, HSS, 3/16 IN CUTTING DIA, 3-1/2 IN LG, STRAIGHT RD SHANK, RH CUT, NOTCHED PT, 2 FLUTES,
X U DZ 1
5133-00-227-9658
DRILL,TWIST, HSS, 1/4 IN CUTTING DIA, 4 IN LG, SIZE E, STRAIGHT RD SHANK, RH CUT, NOTCHED PT, 2 FLUTES,
X U DZ 1
5133-00-227-9650
DRILL,TWIST, HSS, 1/8 IN CUTTING DIA, 2-3/4 IN LG, STRAIGHT RD SHANK, NOTCHED PT, 2 FLUTES,
X U DZ 1
5133-00-227-9666
DRILL,TWIST, HSS, STRAIGHT RD SHANK, RH CUT, 3/8 IN CUTTING DIA, 5 IN LG, NOTCHED PT, 2 FLUTES,
X U DZ 1
5133-00-227-9653
DRILL,TWIST, HSS, 11/64 IN CUTTING DIA, 3-1/4 IN LG, STRAIGHT RD SHANK, RH CUT, NOTCHED PT, 2 FLUTES,
X U DZ 1
5133-00-227-9652
DRILL,TWIST, HSS, 5/32 IN CUTTING DIA, 3-1/8 IN LG, STRAIGHT RD SHANK, RH CUT, NOTCHED PT, 2 FLUTES,
X U DZ 1
5133-00-227-9646
DRILL,TWIST, HSS, 1/16 IN CUTTING DIA, 1-7/8 IN LG, STRAIGHT RD SHANK, NOTCHED PT, 2 FLUTES,
X U DZ 1
5133-00-227-9659
DRILL,TWIST, HSS, 17/64 IN CUTTING DIA, 4-1/8 IN LG, STRAIGHT RD SHANK, RH CUT, NOTCHED PT, 2 FLUTES,
X U DZ 1
5133-00-227-9648
DRILL,TWIST, HSS, 3/32 IN CUTTING DIA, 2-1/4 IN LG, STRAIGHT RD SHANK, RH CUT, NOTCHED PT, 2 FLUTES,
X U DZ 1
5133-00-243-9612
DRILL,TWIST, HSS, 13/64 IN CUTTIN DIA, 3-5/8 IN LG, STRAIGHT RD SHANK, RH CUT, NOTCHED PT, 2 FLUTES,
X U DZ 1
5133-00-227-9664
DRILL,TWIST, HSS, STRAIGHT RD SHANK, RH CUT, 11/32 IN CUTTING DIA, 4-3/4 IN LG, NOTCHED PT, 2 FLUTES,
X U DZ 1
5133-00-227-9662
DRILL,TWIST, HSS, 5/16 IN CUTTING DIA, 4-1/2 IN LG, STRAIGHT RD SHANK, RH CUT, NOTCHED PT, 2 FLUTES,
X U DZ 1
5133-00-227-9656
DRILL,TWIST, HSS, 7/32 IN CUTTING DIA, 3-3/4 IN LG, STRAIGHT RD SHANK, RH CUT, NOTCHED PT, 2 FLUTES,
X U DZ 1
5133-00-240-8443
DRILL,TWIST, HSS, 19/64 IN CUTTING DIA, 4-3/8 IN LG, STRAIGHT RD SHANK, RH CUT, NOTCHED PT, 2 FLUTES,
X U DZ 1
5130-01-050-7977
DRILL,ELECTRIC,PORT, 1/2 IN CHUCK SIZE; 115 V, AC/DC, 60 HERTZ; HEAVY DUTY REVERSIBLE; DOUBLE INSULATED, 690 WATTS, 600 RPM; 2-STAGE GEAR REDUCTION; 6 AMPS, 7-1/4 LBS; CHUCK KEYS, AUXILARY SIDE HANDLE, OPERATING MANUAL,
D M EA 1
5130-01-339-8720
DRILL,HYDRAULIC,POR, 1/2 IN ADJUSTABLE CHUCK; SHOCK ABSORBING PISTOL GRIP HANDLE; 3-1/2 IN WIDE X 9 IN LG NOM DIM; 6 LBS; INSTANT REVERSE FEATURE; 1000 RPM; 2000 PSI; WHIP HOSES W3/8 IN QUICK MALE/FEMALE FLUSH COUPLERS; WCARRYING CASE,
D M EA 1
5133-00-277-2698
DRILL,MASONRY,ROTAR, STEEL; 1/2 IN CUTTING DIA; 3/8 IN SHANK DIA; 6 IN LG,
X U EA 1
5133-00-277-2702
DRILL,MASONRY,ROTAR, STEEL; 53 ROCKWELL C HARDNESS RATING; 57 MULTIPLE BIT CORE MASONARY CUTTING END STYLE; 76 STRAIGHT RD SHANK STYLE; 0.510 IN SHANK DIA; 8 IN LG; 3/4 IN CUTTING DIA,
X U EA 1
5133-00-277-2704
DRILL,MASONRY,ROTAR, MULTIPLE BIT CORE; 7/8 IN CUTTING DIA; 1/2 IN DIA SHANK; 10 IN LG,
X U EA 1
5133-00-277-2699
DRILL,MASONRY,ROTAR, STEEL; 53 ROCKWELL C HARDNESS; 57 MULTIPLE BIT CORE MASONARY CUTTING END STYLE; 76 STRAIGHT RD SHANK STYLE; 3/8 IN SHANK DIA; 6 IN LG; 9/16 IN CUTTING DIA,
X U EA 1
5133-00-277-2705
DRILL,MASONRY,ROTAR, STEEL; 53 ROCKWELL C HARDNESS RATING; 57 MULTIPLE BIT CORE MASONARY CUTTING END STYLE; 76 STRAIGHT SHANK STYLE; 0.510 IN SHANK DIA; 10 IN LG; 1 IN CUTTING DIA,
D M EA 1
5133-00-542-4764
DRILL,MASONRY,ROTAR, STEEL; 53 ROCKWELL C HARDNESS RATING; 57 MULTIPLE BIT CORE MASONARY CUTTING END STYLE; 76 STRAIGHT RD SHANK STYLE; 0.385 IN SHANK DIA; 8 IN LG; 5/8 IN CUTTING DIA,
X U EA 1
5133-00-189-9326
DRILL,TWIST, HSS; 9/16 IN DIA; NO. 2 MORSE TAPER SHANK; 2 FLUTES; 4-7/8 IN LG; RH CUT; 8-3/4 IN LG,
X U EA 1
5133-00-189-9318
DRILL,TWIST, STEEL; 7/16 IN DIA; NO. 1 MORSE TAPER SHANK; 2 FLUTES; 3-7/8 IN LG; RH CUT; 7-1/4 IN LG,
X U EA 1
5133-00-227-9669
DRILL,TWIST, HSS, STRAIGHT RD SHANK, RH CUT, 27/64 IN CUTTING DIA, 5-3/8 IN LG, NOTCHED PT, 2 FLUTES,
X U PG 1
5133-00-228-1349
DRILL,TWIST, HSS; RH; MORSE TAPER SHANK NO. 3; 1 IN DIA; 11 IN LG,
X U EA 1
5133-00-227-9673
DRILL,TWIST, HSS, STRAIGHT RD SHANK, RH CUT, 15/32 IN CUTTING DIA, 5-3/4 IN LG, NOTCHED PT, 2 FLUTES,
X U PG 1
5133-00-228-1345
DRILL,TWIST, HSS; RH; MORSE TAPER SHANK NO. 3; 15/16 IN DIA; 10-3/4 IN LG,
X U EA 1
5133-00-227-9672
DRILL,TWIST, HSS, STRAIGHT RD SHANK, RH CUT, 1/2 IN CUTTING DIA, 6 IN LG, NOTCHED PT, 2 FLUTES,
X U PG 1
5133-00-227-9671
DRILL,TWIST, HSS, STRAIGHT RD SHANK, RH CUT, 29/64 IN CUTTING DIA, 5-5/8 IN LG, NOTCHED PT, 2 FLUTES,
X U PG 1
5133-00-228-1331
DRILL,TWIST, STEEL NO. 2 MORSE TAPER SHANK; RH CUT; 11/16 IN DIA; 2 FLUTES; 5-3/8 IN LG, 9/14 IN LG O/A,
D M EA 1
5133-00-228-1339
DRILL,TWIST, HSS; RH; MORSE TAPER SHANK NO. 3; 13/16 IN DIA; 10-3/4 IN LG,
X U EA 1
5130-00-449-6656
EXTENSION,SOCKET WR, FOR POWER TOOLS; 3/4 IN SQ DRIVE, 7 IN LG,
D M EA 1
5110-00-782-7491
FILE,HAND, PARALLEL RD; SINGLE CUT OR DOUBLE CUT FACE; 8 IN NOM LG HEEL TO POINT; 3/16 IN DIA OF LARGEST SECTION,
X U EA 2
5110-00-323-4732
FILE,HAND, PARRALEL RD; SINGLE CUT OR DOUBLE CUT FACE; 8 IN NOM LG HEEL TO POINT; 1/4 IN DIA OF LARGEST SECTION,
X M EA 2
5110-00-965-0608
FILE,HAND, SINGLE CUT OR DOUBLE CUT FACE; 8 IN NOM LG HEEL TO POINT; 7/32 IN DIA OF LARGEST SECTION,
X U EA 2
5110-00-250-6512
FILE,HAND, AMERICAN PATTERNS CANT SAW; SINGLE CUT CANT FACES & EDGES; 6 IN LG HEEL TO POINT,
X U EA 2
6545-00-922-1200
FIRST AID KIT,GENER, RIGID CASE CONSISTING OF:,
X J EA 1
6545-00-853-6309
Picture Not Available C
7153 FIRST AID KIT,EY, C/O 2 STERILE EYE PADS, 8 ADHESIVE TAPE STRIPS & 2 TUBES OF OPTHALMIC OINTMENT IN A RECLOSEABLE PLASTIC BAG,
X U EA 1
6510-01-060-1639
ADHESIVE TAPE SURG 1", 1 IN X 1-1/2 IN O/A DIM; PERFORATED TRANSPARENT PLASTIC BACKING; NATURAL COLOR; 100 PER BAG,
X U PG 3
6505-00-106-0875
AMMONIA INHAL SOL 10S, AMPUL, 1/3 ML, 10 PER PKG,
X U PG 1
6510-00-200-3185
BAND GAUZE 3INX6YDS, STERILE, CAMOFLAGED OLIVE GREEN; 218 IN NOM LG X 3 IN WD X 1-1/2 IN FOR WD; 1 EA PER PLASTIC BAG,
X U EA 2
6510-00-201-1755
BANDAGE 37X37X52IN, COMPRESSED, FOLDED; OLIVE DRAB COLOR; TRIANGLE SHAPE; 37 IN X 52 IN W/2 SAFETY PINS; 1 EA PER PACKAGE,
X U EA 1
6510-00-597-7469
BANDAGE ADHESIVE 3", GAUZE AND PLASTIC COATED W/ADHESIVE; FLESH COLOR; 3 IN LG X 3/4 IN WD 100 PER BOX,
X U PG 18
6515-00-754-0426
BLADE SURG 2.5"LG 5S, STRAIGHT, SINGLE EDGE, 2-1/4 IN LG, 5 PER PKG,
X U PG 1
6510-00-200-3075
COMPRESS/BANDAGE 2X2", CAMOUFLAGED, 2 BY 2 IN, 48 IN BANDAGE LG, 4 PER BOX,
X U PG 1
6510-00-159-4883
DRESSING FIRST AID, CAMOUFLAGED; ABSORBENT CELLULOSE LAYER AND ATTACHED PLASTIC BACKING AND GAUZE COVERED; 96 IN LG X 4 IN WD BANDAGE; 4 IN X 2 IN FORMED SIZE; 1 PER PLASTIC BAG; STERILE,
X U EA 3
6510-01-112-6414
GAUZE PETRO3X36IN 12S, WHITE COLOR; STERILE; 36 IN WD; 1 PER PLASTIC BAG; 12 PER PACKAGE,
X U PG 3
-01-133-3722
, PLASTIC, RIGID, 2-3/4 IN HGT, 4-1/2 IN WD, 7-1/2 IN LG,
FLOODLIGHT,ELECTRIC, AC/DC, 120 V, 500 W; 1 MOGUL SCREW BASE INCANDESENT LAMP ACCOMMODATE; FIXED BEAM SPREAD; ALUMINUM HOUSING; REFLECTOR AND LENS; R-40 LAMP, BASE MTG; L5-15 PLUG,
X M EA 2
7240-00-559-7364
FUNNEL, STEEL; ZINC COATED FINISH; 1 QT CAPACITY; W/REMOVEABLE STRAINER, FLEXIBLE SPOUT, 8 IN NOM LG,
X U BX 1
5330-00-239-1877
GASKET, SYNTHETIC RUBBER, OIL RESISTANT TYPE, MATL PER MIL-R-2765,3-3/16 IN OD X 9/16 IN ID X 3/16 IN THK NOM DIM,
X U PG 6
4240-00-052-3776
GOGGLES,INDUSTRIAL, SADDLE BRIDGE NOSE, CLEAR PLASTIC VENTILATED FLEX, FRAME, REPL PLASTIC LENS, 2-3/8 IN W LENS OPENING, 18 IN LG HEADBAND, CAN BE WORN OVER OTHER SPECTACLES,
X U PR 4
5130-00-571-6469
HANDLE,DRILL PRESSU, 3/4 IN NPT; FOR PORTABLE DRILL; 3/8, 1/2, 5/8, 3/4 7 1 IN,
X M EA 1
5110-00-595-8325
HANDLE,FILE, 4-5/8 IN NOM LG, 1-5/16 IN DIA; FOR FLAT, OVAL OR ROUND SHANK,
X U EA 2
4720-01-389-3128
HOSE ASSEMBLY,NONME, SYNTHETIC RUBBER TUBE; SINGLE WIRE BRAID REINFORCEMENT AND SYNTHETIC RUBBER COVER; EXCEED SAE 100R1A REQUIREMENT; TEMP RANGE -40 DEG F TO 200 DEG F; 11/2 IN ID, 29/32 IN OD; 2500 PSI MAX OPERATING PRESSURE; 90 IN LG; W/2 MALE END CRIPM FITTINGS EA, 1/2-14 NPT,
X U EA 2
4720-01-361-3661
HOSE ASSEMBLY,NONME, 2-1/2 IN. ID X 25 FT LG; COTTON HOSE; FITTING WITH PIN LUG; BRASS MALE COUPLER ON ONE END AND FEMALE COUPLER ON THE OTHER END; 7-1/2 NH THREADS PER IN; USED W/PUMP UNIT, CENTRIFUGAL, NSN 4320-01-086-2873,
X U EA 2
4720-01-389-3142
HOSE ASSEMBLY,NONME, SYNTHETIC RUBBER TUBE; 2 WIRE BRAID REINFORCEMENT AND SYNTHETIC RUBBER COVER; SAE 100R2A ORAT HOSE STYLE; TEMP RANGE -40 DEG F TO 200 DEG F; 5/8 IN ID, 1-3/32 IN MAX OD, 2750PSI MAX OPERATING PRESSURE; 50 FT LG; W/2 MALE END CRIMP FITTINGS, 1/2-14 NPT,
X U EA 2
4720-01-389-7721
HOSE ASSEMBLY,NONME, SYNTHETIC RUBBER TUBE; 2 WIRE BRAID REINFORCEMENT AND SYNTHETIC RUBBER COVER; SAE 100R2A ORAT HOSE STYLE; TEMP RANGE -40 DEG F TO 200 DEG F; 3/4 IN ID, 1-1/4 IN MAX OD; 2250 PSI MAX OPERATING PRESSURE; 50 FT LG; W/2 MALE END CRIMP FITTINGS, 3/4-14 NPT,
X U EA 2
4720-01-389-3150
HOSE ASSEMBLY,NONME, SYNTHETIC RUBBER TUBE; 2 WIRE BRAID REINFORCEMENT AND SYNTHETIC RUBBER COVER; SAE 100R2A ORAT HOSSE STYLE; TEMP RANGE -40 DEG F TO 200 DEG F; 3/4 IN ID, 1-1/4 IN MAX OD; 2250 PSI MAX OPERATING PRESSURE; 90 IN LG; W/2 MALE END CRIMP FITTINGS, 3/4-14 NPT,
X U EA 1
4720-01-361-3662
HOSE ASSEMBLY,NONME, SYNTHETIC RUBBER TUBE; SINGLE WIRE BRAID REINFORCEMENT AND SYSTHETIC RUBBER COVER; EXCEED SAE 100R1A REQUIREMENT; TEMP RANGE -40 DEG F TO 200 DEG F; 1/2 IN IN ID, 29/32 IN OD; 2500 PSI MAX OPERATING PRESSURE; 50 FT LG; DUAL HYDRAULIC HOSES; W/2 MALE END CRIMP FITTINGS EA, 1/2-14 NPT,
X M EA 1
6115-01-304-0312
HYDRAULIC MOTOR-GEN, 120/240 V, 60 HZ; HYDRAULIC ALTERNATOR; 75 LBS MAX WT; 17-13/32 IN LG X 10-3/4 IN WD X 12-1/2 IN HGT NOM O/A DIM; 15 AMP DUPLEX OUTLET, ONE 30 AMP TWIST-LOCK, ONE 12 AMP DUPLEX OUTLET AMD BUILT-IN VOLTMETER (OPTIONAL); WHIP HOSES W/3/8 IN QUICK DISCONNECT MALE/FEMALE FLUSH COUPLERS,
X U EA 1
5130-01-181-7029
INACTIVE, 3/8 IN EXTRA HEAVY DUTY; KEY JAW CHUCK; DOUBLE INSULATED; 5 AMPS, 598 WATTS; 3-STAGE GEAR REDUCTION; 0-1000 RPM; 115 V, AC/DC; 4-1/2 LBS; CHUCK KEY, AUXILARY SIDE HANDLE; AND OPERATING MANUAL,
M EA 1
5970-00-816-6056
INSULATION TAPE ELEC, ADHESIVE; PLASTIC; 108 FT LG, 0.75 IN WD, 0.007 IN NOM THK,
X U RO 2
6240-00-553-1881
LAMP,INCANDESCENT, A2J MOGUL SCREW BASE; B20 R BULB STYLE; R-40 BULB DESIGNATOR; 7-1/4 IN LG; TRANSLUCENT WHITE LIGHT; 300 W; NOT V RATED; 2000 HRS,
X U EA 4
4210-01-361-5003
NOZZLE,FIRE HOSE, PLAIN, TAPERED ONE-PIECE; 2-1/2 IN THREAD HOSE CONNECTION; 1 IN TRIP OPENING; BRASS; 12 IN O/A LG; USED WITH HOSE ASSEMBLY, NONMATALLIC,
X M EA 1
4930-00-274-5713
OILER,HAND, 1/4 PINT CAP; 6 IN LG RIGID SPOUT; TRIGGER STYLE PUMP,
X U EA 1
5340-00-912-4089
PADLOCK SET, BRASS OR BRONZE MATL, PIN TUMBLER WITH DEAD BOLT LOCKING CONSTRUCTION; 1-31/31 IN HGT, 1-1/8 IN WD; 8 PADLOCKS , KEYED ALIKE, EQUIPPED W/3 KEYS PER SET, W/CLEVIS AND 9 IN LG CHAIN,
X J SE 1
5120-00-223-7397
PLIERS,SLIP JOINT, 8 IN LG, STRAIGHT NOSE, W/CUTTER JAW; 81348 GGG-P-471, TYPE 2, STYLE A, CLASS 2,
X U EA 2
1730-01-342-2184
POWER SUPPLY,HYDRAU, DIESEL POWERED; 27 HP; 3 CYL ENGINE; 2 CIRCUITS; 8 GPM NOM RATE; 59-12 IN LG X 42 IN WD X 37 IN HGT MAX O/A DIM; 1000 LBS MAX WT,
X U EA 1
4240-00-022-2946
PROTECTOR,HEARING, SOUND ATTENTUATIONS 25 DB FOR 500 HZ, 35 DB FOR 1000, 2000, 3000 & 4000 HZ, 30 DB FOR 6000 & 8000 HZ, W/AN EXTRA SET OF SEALS,
X U EA 2
4730-00-679-1686
REDUCER,PIPE, 3/4-14 NPT MALE 1ST END, 1/2-14 NPT FEMALE SWIVEL 2ND END; 1.920 IN NOM O/A LG; CADMIUM OR ZINC PLATED,
X U EA 6
4730-00-143-8937
REDUCER,PIPE, 3/4-14 NPT FEMALE TO 1/2-14 NPT MALE; 1.930 IN NOM O/A LG; CADMIUM OR ZINC PLATED,
X U EA 1
4930-01-361-3676
REEL ASSEMBLY,HOSE, DUAL HOSE SPRING REWIND REEL; FOR TWIN HOSE LENGTH OF 50 FT OF 1/2 IN DIG HYDRAULIC HOSES; 25-7/8 IN HGT X 18 IN WD NOM DIM; 97 LBS MAX; WITH 2 FEMALE RISER 1/2 IN NPT FOR HYDRAULIC HOSE CONNECTION,
X M EA 2
5975-00-878-3791
ROD,GROUND, 3 PCS; 108 IN O/A LG; NO. 6 AWG STRANDED WIRE SIZE X 72 IN LG; STEELROD, 5/8 IN DIA; TERMINAL LUG WITH HOLE TERMINATION, USE WITH HYDRAULIC GENERATOR,
X U EA 1
5140-00-315-2781
ROLL,TOOLS AND ACCE, DUCK; MILDEW RESISTANT; WATER REPELLANT; 49 IN LG, 34 IN W/UNROLLED, W/FLAP POCKET DATA,
D M EA 1
4020-00-874-7920
ROPE,FIBROUS, TWISTED PLASTIC, POLYPROPYLENE MATL; 3 STRAND; 1-1/2 IN NOM CIRCUMFERENCE; 3700 LBS MIN BREAKING STRENGTH; YELLOW COLOR, 50 FT LG; SPOOL FORM,
X U SL 1
5130-00-596-9728
SANDER DISK ELEC 7 IN, 7 IN DIA PAD; DESIGNED FOR HEAVY DUTY; AC/DC, 115 V; W/CASE,
D U EA 2
3895-01-361-3375
SAW,ABRASIVE DISK,M, HYDRAULIC, 14 IN WHEEL; 20 IN WD NOM O/A DIM; 21 LBS; WHIP HOSE W/3/8 IN QUICK-DISCONNECT MALE/FEMALE FLUSH COUPLERS,
X M EA 1
5130-00-089-3354
SAW,CIRCULAR,PORTAB, 8-1/4 IN DIA BLADE; 115 V, 60 HZ; 5/8 RD ARBOR; W/CARRYING CASE, RIP GRADE, WRENCH, BLADE AND OPERATING MANUAL,
D M EA 2
5120-00-234-8912
SCREWDRIVER,CROSS T, PHILLIPS TIP, NO. 3 SIZE TIP, 6 IN LG BLADE, PLASTIC HANDLE,
X U EA 2
5120-00-010-7914
SCREWDRIVER,FLAT TI, 8 IN NOM LG BLADE; PLASTIC HANDLE; FLAT TIP TYPE; 3/16 IN TIP WD,
X U EA 2
5120-01-013-1676
SLIDE HAMMER,GROUND, STEEL, 38 IN LG, 5/8 IN DIA, 5/8-11 UNC X 3-1/4 IN THREADED BOTH ENDS; NUT 5/8-11 UNC EACH END, STRICKER PLATE 4 IN OD X 1 IN THICK, CENTER HOLE 5/8-11 UNC; STRICKER 4 IN OD X 3/4 IN ID X 5 IN HIGH WITH 3/4 OD X 6 IN,
D U EA 1
3460-00-232-8117
SOCKET, TAPER SHANK T, REDUCING DESIGN; FOR STD SHANK; NO. 3 AMERICANSTD TAPER SIZE SHANK, NO. 1 AMERICAN STD TAPER INSIDE, 3-15/15 IN LG,
X U EA 1
3460-00-227-7520
SOCKET, TAPER SHANK T, REDUCING TYPE; FOR STD SHANK; NO.3 AMERICAN STD TAPER SIZE SHANK, NO. 2 AMERICAN STD TAPER INSIDE, 4-7/16 INLG O/A,
X U EA 1
5130-00-236-3979
SOCKET,SOCKET WRENC, DESIGNED FOR USE ON POWER TOOLS; 3/4 IN SQUARE DRIVE, HEXAGONAL WRENCHING SURFACE SHAPE; STEEL; STANDARD LENGTH; BLACK FINISH; 6-POINT STANDARE; 1-1/2 IN NOM SIZE; 2.75 IN MAX LG,
D M EA 1
5130-00-227-6677
SOCKET,SOCKET WRENC, DESIGNED FOR USE ON POWER TTOLS; 3/4 IN SQ DRIVE,HEXAGONAL WRENCHING SURFACE SHAPE; STEEL; STANDARD LENGTH; BLACK FINISH; 6-POINT STANDARD; 7/8 IN NOM SIZE; 2.25 IN MAX LG,
X U EA 1
5130-00-227-6681
SOCKET,SOCKET WRENC, DESIGNED FOR USE ON POWER TOOLS; 3/4 IN SQ DRIVE, HEXAGONAL WRENCHING SURFACE SHAPE; STEEL; STANDARD LENGTH; BLACK FINISH; 6-POINT STANDARD; 1-1/8 IN NOM SIZE; 2.50 IN MAX LG,
X U EA 1
5130-00-293-1411
SOCKET,SOCKET WRENC, DESIGNED FOR USE ON POWER TOOLS; 3/4 IN SQ DRIVE, HEXXAGONAL WRENCHING SURFACE SHAPE; STEEL; STANDARD LENGTH; BLACK FINISH; 6-POINT STANDARD; 15/16 IN NOM SIZE; 2.38 IN MAX LG,
X U EA 1
5130-00-227-6699
SOCKET,SOCKET WRENC, DESIGNED FOR USE ON POWER TOOLS; 3/4 IN SQ DRIVE. HEXAGONAL WRENCHING SURFACE SHAPE; STEEL; STANDARD LENGTH; BLACK FINISH;6-POINT STANDARD; 5/8 IN NOM SIZE; 2.12 IN MAX LG,
D M EA 1
5130-00-227-6684
SOCKET,SOCKET WRENC, DESIGNED FOR USE ON POWER TOOLS; 3/4 IN SQ DRIVE, HEXAGONAL WRENCHING SURFACE SHAPE; STEEL; STANDARD LENGTH; BALCK FINISH; 6-POINT STANDARD; 1-5/16 IN NOM SIZE; 2.62 IN MAX LG,
X U EA 1
5130-00-227-6676
SOCKET,SOCKET WRENC, DESIGNED FOR USE ON POWER TOOLS; 3/4 IN SQ DRIVE, HEXAGONAL WRENCHING SURFACE SHAPE; STEEL; STANDARD LENGTH, BLACK FINISH; 6-POINT STD; 13/16 IN NOM SIZE; 2.25 IN MAX LG,
D M EA 1
7240-00-177-6154
SPOUT,CAN,FLEXIBLE, 1-15/64 IN OD FLEXIBLE TUB, E2-1/4 IN OD CAM END, FILTER SCREEN; 16 IN LG,
X U EA 1
5340-01-361-2014
STOP,MECHANICAL, TWO PIECE MOLDED RIBBER DISK DRILLEED TO ACCOMODATE 1 IN OD AND 1-1/8 IN OD HYDRAULIC HOSES; 3 IN OD,
X M EA 4
5140-00-315-2758
TOOL BOX,PORTABLE, 22 IN NOM LG X 9-1/2 IN NOM HGT X 8-1/2IN NOM WD O/A DIM; 1 TRAY; HANDLE ON TOP; HASP AND STAPLE FOR PADLOCK AND 2 DRAWBOLTS; STEEL; ENAMEL SURFACE,
D U EA 1
5180-01-296-5521
TOOL KIT,CHAIN SAW, KIT CONTAINS 1 EA DEPTH GAUGE; 1 EA FILE GUIDE C/O 2 ROUND FILES, FILE HANDLE, CLAMP AND WING NUT; 1 EA DOUBLE SOCKET WRENCH; 1 EA PLASTIC POUCH,
X U KT 1
5130-01-299-0175
UNIVERSAL JOINT,SOC, 3/4 IN DRIVE SURFACE SIZE, IMPACT; 3-5/32 IN NOM O/A LG; 1-3/4 IN NOM OD,
X U 1
5130-00-542-3313
WHEEL,ABRASIVE, DEPRESSED CENTER; ALUMNIUM OXIDE; 24 GR; OPENING GR SPACING NO. 14, RESINOID BOND, GRADE U; 7 IN DIA, 5/16 IN THK, 1/8 IN W EDGE; 7/8 IN DIA ARBOR HOLE,
X U EA 5
5130-01-361-3373
WHEEL,ABRASIVE, CUT-OFF TYPE; FOR DRY, OFF-HAND CUTTING OF MASONARY SUCH AS CONCRETE, ASPHALT, BLOCK AND NON-FERROUS METALS; SILISOC CARBIDE ABRASICE; 14 IN DIA X 1/8 IN THK; 1 IN DIA ARBOR HOLE,
X M EA 5
5130-01-361-3374
WHEEL,ABRASIVE, CUT-OFF TYPE; FOR DRY OFF-HAND CITTING OF METALS SUCH AS RE-BAR, PIPE; GENERAL PURPOSE; ALUMNIUM OXIDE ABRASIVE; 14 IN DIA X 1/8 IN THICK; 1 IN DIA ARBOR HOLE,
X M EA 5
5130-00-049-7912
WHEEL,ABRASIVE, SPECIAL WHEEL, RAISED HUB; ALUMINUM OXIDE, 24 GR; MEDIUM GR SPACING NO. 5, RESINOID BOND GRADE U; 7 IN DIA, 7/16 IN WEDGE, 7/8 IN DIA ARBOR HOLE,
X U EA 5
5120-01-176-1820
WRENCH SET,COMBINAT, 15 PCS COMBINATION BOX AND OPEN END; 12 POINT BOX OPENING; 15 DEG NOM HEAD ANGLE OFFSET; CHROME PLATED; W/POUCH CONSISTING OF:,
D U EA 1
5120-00-228-9511
WRENCH,BOX AND OPEN, 13/16 IN SIZE,
X U EA 1
5120-00-228-9514
WRENCH,BOX AND OPEN, 1 IN SIZE,
X U EA 1
5120-00-228-9503
WRENCH,BOX AND OPEN, 5/16 IN SIZE,
X U EA 1
5120-00-228-9506
WRENCH,BOX AND OPEN, 1/2 IN SIZE,
X U EA 1
5120-00-228-9510
WRENCH,BOX AND OPEN, 3/4 IN SIZE,
X U EA 1
5120-00-228-9509
WRENCH,BOX AND OPEN, 11/16 IN SIZE,
X U EA 1
5120-00-228-9507
WRENCH,BOX AND OPEN, 9/16 IN SIZE,
X U EA 1
5120-00-228-9505
WRENCH,BOX AND OPEN, 7/16 IN SIZE,
X U EA 1
5120-00-288-9671
WRENCH,BOX AND OPEN, 9/32 IN SIZE,
X U EA 1
5120-00-228-9513
WRENCH,BOX AND OPEN, 15/16 IN SIZE,
X U EA 1
5120-00-288-9997
WRENCH,BOX AND OPEN, 1/4 IN SIZE,
X U EA 1
5120-00-228-9508
WRENCH,BOX AND OPEN, 5/8 IN SIZE,
X U EA 1
5120-00-228-9512
WRENCH,BOX AND OPEN, 7/8 IN SIZE,
X U EA 1
5120-00-228-9504
WRENCH,BOX AND OPEN, 3/8 IN SIZE,
X U EA 1
5120-00-278-0342
WRENCH,BOX AND OPEN, 11/32 IN SIZE,
X U EA 1
5120-00-264-3796
WRENCH,ADJUSTABLE, OPEN END SINGLE HEAD, 0 TO 1-5/16 IN WRENCHING SIZE, 12 IN NOM LG O/A; P/N GGG-W-631,
X U EA 1
5120-00-228-9516
WRENCH,BOX AND OPEN, STEEL, CHROME PLATED, 12 POINT WRENCHING SURFACE; 15 DEGREE NOM HEAD ANGLE OFFSET, 1-1/8 IN SIZE WRENCHING SURFACE, 14-1/2 IN NOM LG,
D U EA 1
5130-01-361-3376
WRENCH,IMPACT,HYDRA, MEDIUM DUTY; 3/4 IN SQ DRIVE; 14 LBS; 250-1200 FT LB ADJUSTABLE IMPACT INTENSITY INSTANT REVERSE; HANDLE COATED WITH HEAT INSULATING, SHOCK ABSORBING MATERIAL; WHIP HOSES W/3/8 IN QUICK-DISCONNECT MALE/FEMALE FLUSH COUPLERS; W/CARRYING CASE,
X M EA 1
5120-00-277-9076
WRENCH,SPANNER, ADJUSTABLE HOOK TPYE; 2 IN TO 4-3/4 IN DIA CAPACITY; 11-3/8 IN LG,
X U EA 1
-00-889-2221
, HAND; 2-1/2 LB; EXTINGUISHING AGENT DISCHARGED BY STORED PRESSURE; W/UNIVERSAL BRACKET,
EA 2
-00-529-5720
, SCREW PT; HOLLOW CENTER; MORSE TAPER SHANK 2; 2 IN DIA, 16-13/16 IN LG,
, 17 IN LG X 9 IN WIDE, NOM DIM; 14 LBS; 1500-2000 PSI PRESSURE, 10-14 GPM FLOW NOM RATE; 30 IN NOM CUT CAP; WHIP HOSES WITH 3/8 IN QUICK-DISCONNECT MALE/FEMALE FLUSH COUPLERS; W/CHAIN GUARD AND SHEATH,
EA 1
