Top Crusing Speed?
motormayhem
Tucson, AZ
How can I tell what the best fast highway cruising speed for my m1009 is? I am planning on taking it to the mountains this week (200 MI) and I want to get there in a reasonable time, but I haven't driven many diesels and have a hard time judging rpms based on engine sounds. What is the best way to find a good speed to cruse at without blowing the motor? I have 35's so I believe I can go faster that a stock m1009. Right?
ragedracer
Phoenix, AZ
I drove mine up to Pinetop/Showlow last month. I've still got the stock 31"s. I ran it at indicated 70 pretty much the whole way. My speedo is off though, and my wife driving her truck said we were doing 65. I think you would be totally safe in that range.
hobie237
Newark, DE
Using the calculator above:
Stock tires-
55mph RPM- 1836
65mph RPM- 2169
75mph RPM- 2503
Top speed: 101mph
With 35s-
55mph RPM: 1626
65mph RPM: 1921
75mph RPM: 2117
Top speed: 114
Top speed figures are theoretical, I have no idea whether drag would come into play sooner than engine redline, but something tells me it would. As speed increases, drag and engine RPM will cut into fuel efficiency rather rapidly.
motormayhem
Tucson, AZ
I'm heading from Tucson to Greer for some skiing at Sunrise. I guess I will keep it around 65-70.
maritimer
Yarmouth, NS
well, keep in mind i am at sea level and runnign stock tires.
i can sustain about 90mph without hearing the engine yelling at me to take it easy, i dotn start hearing that till i hit about 100mph. i wouldnt push it to far past 85-90mph though uinless you are familer with the truck as when you pass the 95mph mark she starts to dance and float in the corners. and more then 30 minutes of that at a time will likely start leading to headaches in the engine bay sooner rather then later
hobie237
Newark, DE
Does the M1008 have the same gearing as M1009, and thus the same cruising speeds?
Not even close. 4.56 instead of 3.08 gears, and the stock tire diameters are different. Top speed of an M1008 is around 72mph (I calculated it once, feel free to plug into the calculator I posted earlier) with the stock ~32" tires. Realistic top cruising speed is 55-60mph.
motormayhem
Tucson, AZ
Update:
Well she ran fine all the way up here at 65mph and got about 25mpg! I was very pleased, however on the way to the ski area the next day it ran fine for the first few miles and then began to loose power and stalled all within about 3 min. Now she wont run for more than about 30sec and the local mechanic told me the injector pump "is full of trash" so he is going to rebuild it for me. :cry: I guess I will be back up here next weekend.
