Mark3395
- 2
- 18
- Geneseo Illinois
Got a wonderful M35A3 with under 4kmi on it. Gotta fix front end shimmy but that shouldn't be a big problem (unless you all know something I don't, which is almost comically likely).
But the thing doesn't want to go over 50mph at 2700 rpm. I think top is 2750. Have checked speed with a GPS gizmo and in fact it's doing about 48-49.
Brakes aren't engaged.
First issue is a stupid question: What is the top end for a 35A3?
If higher, what could be holding it back.
Will check out the tranny to see if I'm light on fluid but I doubt it.
Am not used to the shift points yet. Seems to take a long time and high RPMs to shift to 2d, then 3d and 4th shift soon and smoothly.
Thanks for your feedback.
