Topper bolts
Sportsmanfromkc
Olathe, ks
Anyone have any idea where I can get new bolts for my top?
My m1009 came with only a handfull I took one long and one short bolt to home depot, they matched thread and length to some they had.... Bought a bag full got home and could only thread em in about halfway. The existing bolts I had fit in every hole fine so I'm sure the thread in the clip is fine just wrong bolts from home depot.
Any help is always welcome and appreciated. Thanks guys.
niferous
Houston, TX
You have a Fastenal store there in Olathe. They can match them properly and will probably have them in stock. If not they can probably source get them from thee servicing hub the next day.
KSKC1 - Olathe, KS 66061 | Fastenal
I work for Fastenal and so yes this was a plug for my own company. But they will get you the right bolt more than likely cheaper than the hardware store. :)
135gmc
St Paul/MN
It sounds like you might have metric bolts - I agree with niferous - Fastenall is a good resource. McMaster would be a good supplier if you knew exactly what you needed, and if you needed about 100 of each size, but Fastenall is great for smaller jobs. Home Depot is never at the top of my list for bolts - a good hardware store usually does a better job.
niferous
Houston, TX
Fastenal can blow McMaster Carr out of the water on price. In fact a lot of the bolts on our MV trucks came from us. We are the main fastener supplier for Stuart and Stevenson and down at my location BAE is starting to buy more and more fasteners from us for their trucks.
If you guys ever have a big project just PM me and I'll run up a quote.
Warthog
229
OKC, OK
From the TM 9-2320-289-34P parts manual, one of the bolts is part number 458985. It should be self tapping.
Going to www.tpub.com and search for "458985" this page came up.
5305-01-162-5707 Screw, Tapping
The specs are:
A12 DOG TYPE
0.312 INCHES
1.075 INCHES MINIMUM AND
1.125 INCHES MAXIMUM
STEE
Which translates into a 5/16" self tapping bolt that is 1-1/4" long
niferous
Houston, TX
OK I pulled off one of the bolts today and took it to the shop to size it.
The bolts are body bolts and the size is 5/16-18 x 1.
5/16-18 x 1" Phosphate He x Head SEMS Body Bolt | Fastenal
Now I just grabbed a hex head bolt and matched the washer that was on the factory bolt to a 5/16" x 1" fender washer. As you can see in the picture it fits just fine. If you want a body bolt just because that's what was on there you can get them but a 5/16-18 x 1 hex head cap screw will work just fine. Also any USS or SAE washer will work just fine. I just grabbed the 1" fender washer because its the same size as the one that was on the body bolt.
My opinion is I would want the regular zinc plated bolt as it fits, it's readily available at any hardware store, and it has much better corrosion (rust) prevention than the body bolt.
