- 2,960
- 30
- 48
- Tiro, Ohio
This is an idea I stole from the Canada deuces. Trimmed the rubber off the side of the torque rod ends, drilled and tapped 1/2-13 thread, then bolted on a plate with a spacer washer. Now if I lose a torque rod end, I don't lose an axle. I can get underneath with a prybar and see if any went bad, then replace later on, leaving the truck trail worthy.
Did all 12 ends on the M108, since I was replacing the dogbones anyways.
Had to trim the corners of the plates on some. Where the rods bolt to the center, there isn't much room.
Also added how I removed them, on the ones that you can't swing a hammer at. Log splitting wedge, piece of wood. Hammer in the wedge and most of them pop loose. Then if still stuck, a little torch heat would pop them.
Dennis
Dennis
