torque rod
Superdave
12
Onoway Alberta Canada
I have acquired some torque rods to fit the 5 ton 800 series truck ( # 8728126 ) and wondered if they need replacing very often and are they readily available? what is the usual cost for one? I don't know too much about them and don't own a 5 ton, and thought I would ask here.
OSO
Arlington,Wa
I have a 1953 IHC Bridge truck ,was looking at my torque rods yesterday they look like there about 54yrs old some rubber starting to poke away from the bushing housing. I don't my part# as of yet I'll check on my part # . Post you when I find out.OSO
m139h2otruck
NH
Note that the bridge trucks (M139/328) have a longer (wider) tandem spacing than the rest of the series. This is done with longer torque rods and springs. Some of the parts suppliers have just the rubber insert available, which you would have to press into the rod.
Superdave
12
The main reason I asked about them is that I would like to sell them ( as I do not own a 5 ton or know too much about them ) and I do not know what kind of price I should be asking for them. So if any one could tell me what they normally sell for it would be appreciated.
Dave
M1075
Oklahoma City
You can check for seperation but you will get a lot of service before a failure. However, a failure can be bad, very bad.
It is a tough call when to replace them. Most people don't until they fail. When you make toast and it is burnt, you cooked it too long. When you rods break, they should have been replaced.
Djfreema
Santa Clarita, Ca
I saw an old 5 ton that had been converted to a water truck and had one let go while driving, the whole rear axle ended up tearing out, ripping the brake lines out. They ended up scrapping the truck after that, they definately got their moneys worth. $50 per rod with the inserts is a good deal IMHO.
1,807
You folks can check the FL Roundup thread for pics of the failure on my deuce. I was able to put the rod back on using a hilift jack and then strap it into place to get me home. Check the rubber for dryrot. The usually won't pop off unless you are binding up the truck off road. There is almost no lateral movement on the rods during highway travel.
