Tow bar foot for LMTV ?
73m819
325
gainesville, ga.
I believe they you can use the standard 1" adapters with the medium tb.
Suprman
696
Stratford/Connecticut
They should work with the lower hole on the front shackle mounts. I have used the older style m939 shackles in the lower holes.
mkcoen
381
Spring Branch, TX
I haven't seen one like that with the bushing in the middle. Is the pin 1"? Or is that a 3/4" with the bushing making it bigger?
1951M1078
185
Glendale,AZ
This is the adapter for the medium bar from Ibis TEK .
I'm told the big pin is .873". Think that is the clearance for the 1" hole on my bumper ?
1951M1078
185
Glendale,AZ
No, are your feet able to be used on the Ibis tow bar ?
The reason I ask is because I thought maybe I need to use only their feet.
