Tow eye dimensions
aw113sgte
1,408
La Crosse, WI
Wondering if my FMTV tow feet will work with some sleeves (1.0") to be able to move the MTVR around. Could someone please take these two measurements?
20,763
A = .7665
B = 1.4075
C = 1.6005 - That is a big hole... Much bigger than the LMTV
NOTE: I made an EDIT to "B".
I expected the measurement to be the hole size - and not the left-right dimensions of the tow bar mount.
aw113sgte
1,408
La Crosse, WI
Well looks like the fmtv mount won't fit without a little grinding. 0.02" too narrow.
Edit: saw the dimension correction above. Looks like it will fit for moving around slow, but not enough room to put in a sleeve.
MTVR on the left, FMTV adapter on right
Connected:
