try the TB FROM HE!!, about #350I have several adjustable bars and one nonadjustable... Ill go check but I think they use the same size pins...Im not familiar with a bar bigger than my nonadjustable one...It is as heavy as I would want to cart around...
Sounds like you have a medium towbar (adjustable) and a heavy medium (non-adjustable). It is very rare to find feet for a medium that will work properly with large trucks like M915 series. Standard 1" feet can/have been used with the M915 using the tow shackles in emergency situations (see thread by Streetbikedepot). Towbar was originally rated for up to 40,000# and up to M911 tractors (unladen).I checked my towbars...The small adjustable one has 1 inch pins, the bigger nonadjustable one has 1.125 (1 1/2 pins....are there proper 915 feet for either of these bars or do I need to use one with 1.5 pins????
1.125 = 1 1/8 not 1 1/2I checked my towbars...The small adjustable one has 1 inch pins, the bigger nonadjustable one has 1.125 (1 1/2 pins....are there proper 915 feet for either of these bars or do I need to use one with 1.5 pins????
Unlike medium towbars, heavy towbars are not very expensive. Like medium towbars, freight is a killer! I have an extra in OKC I can sell you if you come this way anytime soon!Ok, Im interested in buying a heavy towbar...what kind of money are we talking?? I want some feet to work with my heavy medium bar as well...
I had to edit the 1 1/8 because it put a smiley face there...when I edited I forgot what I was doing...my medium heavy uses 1 1/8 pins...1.125 = 1 1/8 not 1 1/2
