Towbar near Concord,NC
Rebelpride
Thomasville, NC
My deuce is down and sitting in a gas station parking lot, I have a 2nd deuce that I could pull it with, but no towbar. Does anyone have one that I could borrow OR maybe a drawing to show how to make my own?
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
RE: Re: RE: Towbar near Concord,NC
I just noticed "The trucks stop here." in your sig line! BWAAAAhahahahaha
Sorry, don't kill me.
jwaller
19
Columbia, SC
pump not running doesnt have anything to do with it although you want to eventually fix it.
did your fuel cutoff lever return to the proper position when you pushed the cable in?
gimpyrobb
27,785
749
Cincy Ohio
I didn't really think about that. You could get a buddy you trust to pop the clutch to get it home to work on.
1,176
If you are convinced that it is your intank pump that is keeping it from starting, why not use your leaf blower to pressurize the tank and get it home under it's own power? How far do you need to go to get home? Not only can you pull a deuce with a chain, you can push it with another deuce too. My first investment after getting a second deuce was to buy a towbar. One last McGuyver would be to go buy a common 12v pulse type universal fuel pump and wire it direct onto a single battery. Disconnect the hard line to the intank pump and push a hose over it and connect the new pump(outlet) to it. Open your fuel tank and drop a hose into it and connect it to the inlet side of the new pump. It would solve your problem temporarily and get you home. You have several options.
jwaller
19
Columbia, SC
many many ppl have driven their deuces for years without an intake pump. you dont have to have it for it to start. it helps but it's not a requirement.
Rebelpride
Thomasville, NC
Alrighty gents, got the truck started and home. All it needed was a little either, will not restart after shut off, so I will be needing the in tank fuel pump. Also changed the fuel filters and they had fine rust particles in them.
