towbar on bumper
1,172
MarcM35A2
Wiehl/ Germany
Because this Bar is the newer version. If you want to mount it you have to fix it like this. The older (smaller) Towbar is a little bit smaller at the ends of the Frame. And the newer one is a little bit tightened. And with these strond ends you can´t fold it together. So you have to turn around the leg. You know wat I mean?
Greetings Marc
MarcM35A2
Wiehl/ Germany
Is this the official way to fix it on the bumper? I only know the bars strapped on the bumper as I did!
But really a nice way to carry it. But I think the german police wouldn´t like the fixed bolts on the bumper...... but I should try! ;-)
Greetings Marc
maddawg308
745
Front Royal, VA
There is no official way to attach a towbar to a deuce bumper, the towbars are BII for wreckers only. nickd's setup is custom, and non-official.
roger-wilco-66: sorry, you'd have to hit up nickd for more pics, this is the only one I have.
jesusgatos
on the road - in CA right now
I was thinking about grinding down the MWO collars on my towbar, but KsM175 directed me to this thread and that got me thinking about reversing the 'short' towbar leg. I saw the way that MarcM35A2 did it, but that would require you to switch the leg back before you could use the towbar. Is there any reason why you couldn't/shouldn't just leave it set-up like this instead? I can't see there being any difference in strength, as that leg is only in straight tension/compression.
jesusgatos
Oh, and by the way - why is the short leg actually so much shorter than the long leg? Even when the legs are spread to the width of the shackle-mounts, the lunette-eye is off-center. Are all of the towbars like this?
