towing a lmtv
mogger7
gloucester Va
what is the issue with flat towing any distance the one i bought in texas is at a residance and a tractor trailer cant get into location and its a couple miles to a large parking lot
Coffey1
499
Gray Court SC
You can flat tow as long as you stay close to 35mph.
Towed mine 65 miles back roads.
Didn't pull anything and haven't had any problems with truck after fixing it.
sandcobra164
321
Leesburg, GA
I tow these in the National Guard sometimes. If I'm taking a broke truck from the field to post (under 15 miles) I don't pull the driveshaft and keep my speeds low. I check the truck afterwards and have not noticed a hot transmission or transfer case. If we're going long distance I pull the rear shaft and raise the front end with my wrecker's underlift.
Suprman
705
Stratford/Connecticut
The trans is designed so the fluid pump is driven off the output and as long as there is fluid in the trans it will circulate while being towed. But I wouldnt go on the highway or anything crazy.
73m819
328
gainesville, ga.
The -10 gives the towing specs, there is a max distance and max speed, ANYTHING over these maxs require the drive lines/rear axle pulled .
