TOWING A M146 w/ F250
this is what NOT to do.
Works fine for towing around the place here but even i would not try it on the
road.
pulling it would be no problem. stopping it ............................?
I need to use 4 wheel drive to get it thru the sand.
0 pounds tounge weight.
crazyplowboy
Champion, Ohio
I almost had a heart attack when I read the topic line. I was expecting to see somebody recovering an M146 with a pickup truck. I'm not saying that a pick up would not be capable of hauling that kind of weight, but it would not be safe. Unfortunately I know all too well from hauling some of our farm equipment with my Chevy 2500 HD just because the truck is capable of pulling it does not mean you should do it. Glad to see that you used common sense and did not haul it anywhere over the road.
Naaa .
even i am not that crazy! there are a lot of things i will do that make folks shake their heads. but dragging something like this down the road at high speed is to risky for me.
i needed to move it and the F250 happened to be the closest pintle hitch.
sorry about the heart attack. maybe i should have named the thread something different.
this is about the only way i will pull a dolly with the p/u down the road.
empty!
ida34
33
Dexter, MI
The trailer is really only about 7000 lbs. If you could hook it up with a fifth wheel in the truck it would probably not be that bad except for no brakes. Not saying it would be smart but most of the fifth wheel or goose neck travel trailers are at or more than 7000 with comparable surface area to catch the wind. Interestingly enough, the wheel carriage on M146 is only held on by four large bolts and the brake system is attached to glad hands under the trailer. The carriage assembly is probably about half the weight of the trailer.
you are rite about the weight.
with the dolly under it its 10,000 pounds with no toung weight.
no big deal as i was just using it because im lazy and the F250 was the closest.
i would have no worries towing it down the road if the brakes were compatible between the 2 units.
DavidB
27
Southeast Wi.
Thought here goes a wreck story and a chance to get a ladder for the M146,I need two for mine still looking.Glad to see it is an around the yard story and done safely.
DavidB
AndrewH
Boyne City MI
Dave, oh Dave.....
I admit, even I thought I was going to see some carnage. I am happily dissipointed. However.........now I want to try it with the dually!
i have pulled casket trailers with a dolly behind my 88 ford f350 7.3 l not a problem even moved couple for the police dept. here had a police escort behind me as i had the convoy lights on my truck just gotta second guess the morrons in the other cars
jeep-Jeep
Liberty Hill Texas
I want it for my xm818
none for sale here but I saw a nice one in Alaska
6 were on gl out of ft hood and I called to preview and they were pulled from the sale a hour later .
looked like they were full of goodies and were tan color like new :cry:
AndrewH
Boyne City MI
Are the fifth wheel camper kingpins the same size? Has anyone tried that yet? I can see a bunch of bad things come from this. I like it!
