I won a M1009 off of govliq a few weeks ago because i wanted a vehicle to tow my M38A1 and store my equipment for gun shoots and camping trips.
The M1008 series was better equipped for towing but I wanted to do highway speeds while commuting and liked the decent mileage the M1009 got. I also wanted more seating capacity. So I went with the M1009 instead.
Since the stock M1009 isn't the best towing vehicle in the world there are a few upgrades I am going to do.
My mission requirements:
Tow a M38a1 4-6 times a year 50-250 miles at 55-60 mph. The M38a1 weighs about 2,670 lbs with no crew.
To accomplish this I plan to do the following:
1. Install a good transmission cooler to augment the stock system.
2. Install a Class 3 trailer hitch.
3. Use a tandem axle trailer setup that has electric breaks.
4. Install a break controller.
I am planning on purchasing a 16 foot trailer that will have 2 axles and electric breaks. Most setups this size weight 1,500-1,800 lbs.
So I am looking at a total towing weight of around 4500 lbs. The civilian towing capabilities listed by GM are around 5,000 lbs.
I think with the above setup even with the 3.08 axles It would be ok if I drive smart.
What do you guys think? Should I get a trailer with a anti sway bar?
