Town mechanics Messed up M1008
dstang97
30
Clover, SC
Picked up a M1008 and this thing is a nightmare. I have been around some time and have never seen any wiring Hack job like this one. They had a starter issue and kept going through starters. So I messed around with it today and fist i thought bad starter relay. Ok bypassed that to try to see if that was the problem and no dice. So i dropped the "new starter" Some one put in a 12v gear reduction but failed to convert to 12V. Also I noticed there was grade 8 bolts Heli-coiled into the block and were not running a brace. Can I take out the Helicoil? and try an oem bolt? how do i take them out?
Trucks :: IMG_0070.jpg picture by Dstang97 - Photobucket
1,178
If they only had the TMs...
73m819
325
gainesville, ga.
I'm guessing that thay BROKE bolts off in the block, drilled them out, screwed up the threads, hence the thread repair, the oem bolts should thread in, do not think a over size bolt will fit though the starter mount holes
Nonotagain
41
Parkville, MD
thats what i figured. Maybe they used the same thread as oem. I doubt it I'm not that lucky, but I will find out tomorrow.
It could also be that they broke a starter off because they were not running the brace and damaged the threads.
Most mechanics today have never seen a diesel CUCV or know that it has a split electrical system with both 12 and 24 volts. Almost as bad as the British cars that used positive grounds.
dstang97
30
Clover, SC
So tomorrow I may get a new "DAWG" head starter relay. and see if i can dig up some OEM one. I may rob a starter from another CUCV. I will post pictures of the truck tomorrow. You guy will not believe this.
Doghead - Not having the Manuals is no excuse for what they did to this truck. You will see tomorrow.
1,808
This is what happens when someone not familiar with the ingenious design of the electrical sytem starts monkeying around with it. Glad no civilians touched my broom.
ryan77
56
Cary IL
Getting a good mechanic for any car is tough now, Its hard to find some one to trust and who knows what there doing!!! I got a great diesel guy but he's almost 2 hrs away!!! But its worth the drive!!!
cucv1833
Lake Charles, LA
Sorry to hear about that.
Thats why i gave up on my m1008 I kept breaking starter bolts cause it didnt have the brace. So when i went to install the brace the bolt for the brace broke inside the block. Ive extracted the starter bolts about 3 times and the last time didnt go to good. I now have a HELI COIL with a 7/16 bolt on one side. and retapped the brace bolt half **s. but it works.
The TMs. ive tried to upload the Tms on the CUCV tech manual page but there to big. Iv uploaded the Tm-12 though
Whitey
Central Maryland
Hope this is OK to post, TMs are here:
JATONKA's CUCV TM download page
Use John's page for the TM's. It's where I've been going and they've always worked just fine and dandy. Good luck.
btw, all this talk about the brace being missing makes me want to crawl under the truck and double check. Thing is, I had it on the lift last weekend and I know it's there. I seem to second guess everything these days. Better safe than sorry!
1,808
On that note - have the problems with the technical manuals web page been figured out yet?
Yes, there is a short between the steering wheel and the drivers seat! LOL
They will be included with the improved site. Release date is set at .............?
Barrman
1,777
Giddings, Texas
My M715 had two seperate wiring systems in it by the time I got it. Stock and what the town mechanic had run to make things work as they broke and he couldn't figure stuff out. When I got it, it needed to be inspected. He actually asked me what all those levers on the floor do while he was inspecting it.
I agree with the post above. The helicoil is probably the same size bolt as stock due to starter motor hole size. Same thread seems to be the big question.
