CanonNinja
- 7
- 0
- Houston, Tx
Finally something real to fix on the truck. Over the last year, I've lost 3 headlights, just realizing they've all been on the same (driver) side. The last outing in the truck was interesting. I usually run my hazards on the freeways here, too many Dale Earnhardt-types in Houston. I decided to run my headlights for a bit, they were on about maybe 10min before I came up behind a car and noticed the headlights were dimming out on me, flickering almost. I look down, to my surprise, and see smoke coming from the 3-lever. Shut it off, and that was that. Got to my destination, and noticed that I had also lost the driver side front marker light bulb.
I unplugged the headlight on the driver side, tried the switch, nada on the headlights, completely out. About 4 hours and 70 miles later, I try the headlights again, and to my surprise, they flicker for a second, but gave the truck gas and they lit up fine, same with the convoy lights. The headlights would dim/flicker intermittenly, and the convoy lights would also lose power. Finally at the end of the night, lost the driverside headlight again, but the passenger side works fine, still a quick flicker once in a while.
Service lights were working fine still. Is just my 3-lever toast, or do I need to look for shorts in the wiring harness as well? Im thinking of just replacing the entire cab/lighting harness and 3-lever at this point.
