- 193
- 66
- 28
- Austin, TX
Moderators- advise if this is not the right forum but I believe the 5-ton forum is the right forum for this post because it deals with how to use/modify/adapt a 5-ton.
I want to buy a decent equipment trailer (GVW ~24-30k) so I can haul backhoes, mini-dozers, etc. Now that I own a M923, I really want an equipment trailer that I can haul additional future MV's now that I got bit by the green bug!! I own a 1-ton diesel pickup that can tow this trailer but obviously there is an issue with brakes preventing the same trailer to be used effortlessly between my pickup and my M923.
So...
Do I get a trailer with air brakes (fairly common setup and availability at local auctions) to use easily with my 5-ton and then find a way to adapt it to my pickup? How do I do that?
Or do I get a trailer with electric brakes to use with my pickup and then find a way to adapt it to my 5-ton? How do I do that?
Assume it will get used equally between the pickup and 5-ton. I just need to know what's possible or safer when doing the air-over-electric or electric-over-air thing. I'm clueless in this area and I'm dubious of the 'quick and easy' adapters on the interwebs...need some expert advice.
So...
