Trailer from Salem OR to Greenville SC
fasttruck
633
Mesa, AZ
Nick: trailer appears to be a M871 22.5t trailer which has 12 and 24 volt light hookups and common air connections. You moved one for me last year that was empty. The lights are all 12 volt and resistors are provided to knock the 24 volts down to 12. I would guess the one in the picture is about 12.5' high. Ocean freight container would be attached to trailer with the trailer's built in pin locks.
319cssb
221
Easley SC
This trailer is a water purification unit WTA-060. It comes with a mep 806a a sea container. A very nice trailer and a bunch of brass. Besides of that . I don’t know much about these units. But I need to get it to South Carolina
19,750
Nice looking trailer.
Have you got something to drag it around with when you get it to your place?
19,750
Once I get it here, yes . I am working on getting a mtv .
Neat. The M1088 drags that trailer pretty well - at least empty. The CAT 3126 feels fairly strong. The exhaust brake makes a really big difference too when it is time to stop. Only thing that bugs me a bit is that the jacks are not tall enough to raise mine high enough without "cheaters" to attach and disconnect from the tractor / 5th Wheel.
fasttruck
633
Mesa, AZ
Most military trailers have inclined ramps behind the fifth wheel to lift up low trailers. Especially when you are relaying a trailer brought to an interchange point with a M 915 which has a 48" high fifth wheel and you are going to run it to the field with a M818 which has a 60" high double trunnion fifth wheel. The frame heights are similar so you can scoop up a low trailer with the ramps. Just make sure the trailer is chocked or the brakes work unless it against a loading dock. When uncoupling a loaded trailer pull out slowly so the landing legs don't go through the floor. These maneuvers can take on a whole new dimension in snow season when the motor pool is paved in ice.
