mcii
- 2
- 0
- Wimberley, Texas
I have several trailers, all late model and used to carry differing generator sets. Before I just cut off the large bulky multi pin original as supplied connector body and go for the typical 4 pin flat plug. What is the most common way we transfer power for the lighting system, is or does someone offer a converter receptacle for this plug or what is the most viable solution, while I am at it, what about the now supplied 24 v lamps, I don't see it worth the effort to buy or build up some 12-24 supply, with the advancements in LED lamps has this been addressed or solved to make it a simple effort to use on these type applications.
All help and answers welcomed. thank you: mac/mc
