Trailer Tongue Toolbox
dnote
Glen Burnie, MD
I need a toolbox for my M101A2. I want the kind that sits on the tongue of the trailer but my spare will be mounted to the front of the tub which doesnt leave much space. Ive googled to no avail for a box that is 18" wide in the back, 12" in the front, and 10" front to back. Height doesnt matter.
Anyone ever see one this small? Every **** one I have found is at least 2 ft wide.
gungearz
northwestern indiana
You can fabricate a box out of sheet metal for a nice custom fit or you can mount a heavy duty plastic tote to it... I don't think there's a tongue tool box out there that will fit it good...
MarkM
CODE BROWN...It's all going to sh~t !
1,950
WOBURN. MA.
One box that I have seen that works well comes from the generator trailer. Hard to find but sure fits the bill if you can locate one. Why don't you mount the spare on this inside out of the way? I know it takes up a little space inside but it's really not much.
Mark
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
Don't forget about the 20mm cans, they are nice and big. With the spare behind it, it would look proportional too.
Jeepsinker
455
Dry Creek, Louisiana
The 20mm can is about three times the size of the 40mm can, but is just as long. If you set two 40mm cans side by side and then layed another on top of them but on it's side, you have about the same cross section as the 20mm.
dnote
Glen Burnie, MD
Looking proportional is good but I only have so much space to work with. I'll check them out. Whatever I get can't hang over the sides of the tongue too far or it'll hit the truck in a right turn.
