Trailer Wiring
Croatan_Kid
New Bern, NC
I rewired my trailer today and I was messing around with the miltary trailer plug. I figured out what holes do what when using a 4-prong, flat wire, but with it hooked to the trailer, the turn signals are very slow blinking and don't like to work.
Should I just go under the truck and splice into the turn signal, tail light, and brake light wires?
BTW:
H - ground (white wire)
B - left signal (yellow)
J - right signal (green)
E - tail lights (brown)
JohnFire
Pottsville, PA
I would put a heavy duty flasher unit in your truck, they are 10-12 dollars instead of the 2-3 for a regular one fixed my trailer signal light issues. Mine had acted a bit screwy.
blackout
new jersey
my truck did the same thing i cleaned all the grounds i found now it works great britest trailer lights i ever had they are so brite i had to check to see if there was 24 volt going in there but it was 12 volt
AJMBLAZER
Paducah, KY
The guys here usually find a military trailer plug, cut it in half, then combine the truck end with a civilian plug end and wallah, instant civilian trailer plug.
I bought a 4 plug harness for Big Ugly that just plugs into the tail light wiring...however I have to fix my tail light wiring to get it to work right now.
emmado22
143
Mid Hudson Valley NY
Devilman,
You need to offer the INVERSE of that.. Something that allows a civy truck with a 4 wire or 7 wire to pull a mil trailer with the mil plug......
devilman96
17
Boca Raton, FL
It would take a lot more to add the 7 wire to the truck... On a CUCV for example I would need to build a harness for the truck it's self including replacment Mil plug, GM weather tight plugs, fuse block, etc in order to make the whole deal "plug and play"... I prolly have all of the parts I need as I stock almost every GM connector ever made (in my personal collection of stuff) but It would be an expensive little build to say the least... 200$+ (just guessing).
If its something you "have to have" I'll build you one... Everything will plug in nice and neat, install in about 20 mins, but its not a $20 idea.
mangus580
282
Western NY
For towing my M116 with the wife's Suburban, I just got some bullet nose connectors and a flat 4 plug. I found the right wires under the junction cover on the frame rail of the trailer. Unplugged the appropriate wires and plugged the bullet nosed conenctors in its place. If you were really fancy, you could put packards on in their place, and still have a waterproof connection.
AJMBLAZER
Paducah, KY
Yowza, it was just a thought. No real need anyways as my trailer is about M101 size and capacity but civilian so probably weighs half as much. Flat four is all it has for a connector. Thanks though.
four_by_ken
Allenton/MI
Did you ever go any further with this idea?
