Okay first off, after returning from Bjorn's yesterday evening i decided to do some more work on the deuce, i removed the tranny floor cover, i noticed what looked like 2 lifting points on the tranny one was on the drivers side left corner and the other passenger side right rear corner, are those for lifting the tranny as i didn't see any other anchor points.
Second, how in the world do you remove the drivers side engine mount bolts on the front of engine, the steering box seems to be in the way, am i to assume the steering has to be removed or would it be a good practice to remove anyways that way no damage occurs during engine removal.
Also to use the come-a-long and 4x4 post to drop down tranny would you need to lay post from door to door or run post north and south in cab(facing firewall to back cab glass) hope someone understands what im talking about there.
The only thing about today is with those storms in the gulf, were getting hammered today with rain and not one thing i can do...
