Tranny/Transfer Drain Plug Dimensions
FSBruva
Marietta, GA
Good evening-
What are the size/thread dimensions for the deuce transmission and transfer case drain plugs? I am looking to install magnetized plugs, but need to know their dimensions - preferably BEFORE I pull the plug out to drain it...
Matt
builder77
While we are on plug sizes does anyone know the thread size of the engine oil pan plugs?
gringeltaube
Staff Member
2,396
Montevideo/Uruguay
TC : 1 1/4" NPT,
Tranny : 3/4" NPT
Diffs: 1"x 20 TPI
Matt, better check yours before buying, some of the drain plugs already have magnetic inserts!
Builder77: Oil pan plugs (MF) are 7/8"x18
FSBruva
Marietta, GA
gringeltaube-
Thanks for the advice - I have gotten that response a lot. My transmission doesn't have a magnet on it. While I was still learning to drive the deuce, I kept forgetting that 1st and Reverse have no synchros. At my last transmission oil change, nothing was hanging on to the plug, but there was some stuff in there that SHOULD have been hanging on the plug.
Matt
acetomatoco
Never heard of synchro reverse..however you can double clutch the xfer case from low to high in reverse to get a fast back up....remember to always start in first or reverse to save clutch.. and to be sure the sprag is pointed in the right direction on early trucks.. ACE
sponaugle
Portland, Oregon
TC : 1 1/4" NPT,
Tranny : 3/4" NPT
Diffs: 1"x 20
I did my first maintenance yesterday and went to replace all the diff fluid. Two of the diffs have very damaged fill plugs (rounded out square holes).
The drain plugs on the diff are easy to find as they are 3/4 NPT, but the full plugs are not a tapered thread. It was suggested by you and a few other people that the threads are 1" x 20, which I take to mean 1" by 20TPI (Threads per inch). This is a pretty fine thread for a 1" diameter.
I spent some time looking at McMaster-Carr, as well as a bunch of other places online with no luck. I can't find any reference to ANY plugs being 1" x 20.
I did find a 1" x 20 TAP (Greenfield 1? X 20 TPI Hand Tap 1X20 USA | eBay) which was for sale on Ebay, so I suspect there must be some other use.
So, does anyone have a source online, or local that sells a plug that will work for the 1"x20 fill plug on the diff?
(Also, the part number for this plug is 5365-00-732-6126)
Jeff
sponaugle
Portland, Oregon
I have continued on m quest to find a replacement fill plug for the Rockwell differential.
As you can see in the picture attached, there are two plugs on the Rockwell diff. The one I am looking for is #4 in this picture, part number 5365-00-732-6126.
A bit of google search confirms this is the right number, but does not really point to any direct source of the part. I did find a RFQ from the feds for this part, and it looks like it was awarded:
"SPM4A6-08-X-0457 has been awarded on July 9, 2009 to Cage 1SDG3, Barnegat Bay NCCS, Inc.". So, I guess the military also needed some of these plugs.
Anyone have any idea who I might be able to buy the part from based on the NSN?
Jeff
1,172
Have you tried Memphis Equipment, Clark trucks, Whiteowl, Jim Henry, Boyce Equipment, Eastern Surplus and any of the other MV truck shops?
Have you tried the custom axle shops?
sponaugle
Portland, Oregon
Thanks for the suggestion list. I have contacted a few rockwell axel shops, plus boyce, and I'll call Eastern Surplus as well. Clarks is on my list after that.
I'll post back if I get a hit somewhere!
Jeff
sponaugle
Portland, Oregon
Jeff
Memphis had them in stock. woo hoo!. Unfortunately the fill plug in the front diff is completely rounded off, and will not budge even with vise grips (on the edge of the plug). I spent about an hour trying it loose.
My next idea is to weld a bolt to it. Anyone see a problem with that approach, assuming a quick tack with minimal heat? Any other ideas of how to get a stuck fill plug out?
Jeff
kastein
25
Southbridge MA
I would stuff the biggest bolt I could into the hole and weld it in, then turn the bolt. You will fry the oil a bit and wreck the seal (if any) on the plug but you are replacing it anyways.
HDN
4,906
Finger Lakes Region, NY
I'm in the process of pulling the drain plugs out of my transfer case because their square holes are also rounded off and messed up. I may be able to get the fill plug off with heavy pliers or a pipe wrench since there's enough of it exposed.
I was thinking about replacing the plugs with galvanized steel plugs meant for indoor plumbing. Would this be problematic?
This is what I'm thinking about getting: https://www.homedepot.com/p/LDR-Industries-1-1-4-in-Galvanized-Iron-Plug-311-P-114/202310552
And I attached a pic of my messed-up fill plug.
Modiconman
12
Richmond, VA
My transfer case plugs were rounded. I too contemplated welding a big nut to them, however,I was fortunate enough to be able to get a good enough "bite" with a regular pipe wrench and get them out.
  • Like
Reactions: HDN
HDN
4,906
The truck shop used a pipe wrench with cheater pipe to get the fill plug out, and then they welded a bolt to it. For the drain plug, they ground down a bolt to a square shape and pounded it into the rounded off hole (that bolt isn't coming out any time soon!).
The job cost me $200 - the most-expensive drain plugs I've ever had! And they were stuck! Fortunately pulling the fill plug showed that the transfer case has plenty of oil in it despite leaking from the range selector seal.
