Andydieselpower
- 3
- 18
- Owatonna, MN
2nd question asking about air shift for the transfer case located on top of the transmission.
My truck is currently blowing air out of the vent tube while in neutral. When I put the truck in reverse the air leaks go away. I did spray a soapy water spray over the assy. and I had bubbles coming out of the gaskets also.
The air shift assy. on top of the tranny is approx $200 for Memphis Equipment. Any tricks to installing this setup?
Is there a way to bypass this setup altogether? Could you install a manual valve in the air line that you can switch on when you want?
What exactly does this air shifter accomplish on top of the trans? If I unhook it completly what would happen? Thanks,
Andy
Andy
