- 3,021
- 221
- 63
- eldersburg maryland
ok, i think i did this right, but want confirmation...... ratios that are all reduction can just by multiplied to get the net result, like trans x transfer x rear = total ratio. in an overdrive trans there is typically a reduction then a increase in speed done through two gear sets. so........ input gear has 29 teeth, driven countershaft gear has 42 for a ratio of 1.4483 : 1 then the countershaft gear for 5th has 48 teeth and mainshaft 5th has 22 for a ratio of 1 : 2.182 so what is the overdrive ratio?? i get .664, yes? this gearset would give a stock m-35 a 60 mph rpm of about 2125 depending on exact tire size, sound good??
