Trans Leak
ssdvc
639
CT
OK, I am trying to fix all leaks and drips coing from my truck. My driveway doesn't like it and neither does the wife. I am addressing two so far and while a friend of mine was checking out the underneath of my 09, he noticed a leak from this area:
It is the shift arm for the trans and I assume that there is a shaft behind that arm and nut. it has a nice little drip going. Is this easily fixed with an "O-Ring" I can replace?
porkysplace
1,487
mid- michigan
It is a seal ; https://www.classictransmissionsolu...MI596onuXG9wIVvhXUAR3wtgWnEAQYASABEgKjTPD_BwE
ssdvc
639
CT
Awesome, thanks Porky. So I assume I just remove that nut, pull the arm off and fish the old seal out, then reinstall?
Keith_J
1,318
Schertz TX
Fishing the seal out is easier with this tool:
There is a sharp shoulder on the shaft which can cut the new seal. This is why he used that mylar film. Thin heat shrink also works.
ssdvc
639
CT
Thanks Keith. Where do you get the tool? That seal looks tough to remove without it and I will be doing while the trans is in the truck.
cucvrus
10,225
Jonestown Pennsylvania
That is the shift arm for the transfer case on the NP208 C. That was NOT rebuilt.
NP208 Fully Rebuilt Transfercase - Hillbilly Wizard
This one was rebuilt. That seal is available at NAPA. Getting all the leaks fixed on 35+ year old vehicles is a full time labor intense job. Good Luck. I found changing the seal will work sometimes. But never all the time. Mud gets in the seal and like a pipe cutter grooves the shaft and makes a seal unsealable. I started taking units to shop that leak after a seal replacement because they require being split and the selector being changed to correct the leak. Almost 40 years and leaks and worn parts are bound to happen.
Amazon.com: oil drip pan for under car
I see catch pans under military vehicles at Fort Indiantown Gap all the time. Like Murphy's Law. Leakproof seals will.
ssdvc
639
CT
Well crap ! Hey Rick, is that seal the same one I just ordered In an above reply), or a different part number?
