coachgeo
- 3,404
- 113
- North of Cincy OH
![s-l500.jpg s-l500.jpg](https://www.steelsoldiers.com/data/attachments/445/445993-54cbcbe68c55a814e7712533e3e9da36.jpg)
apparently, other Allison Tranny's with a Rear added T-Case have issues with breakage from vibrations. Though the one described below appears to break in different location from unintended vibrations than the 3070/3700 version in our trucks the result is the similar. Just throwing out there as an interesting tid bit! Not pointing out that this is a for sure weak point on our trucks; esp. if on does meticulous maintenance.
Found on FleeBay:
"PPE 129020710 Transfer Case Brace For 2007.5 - 2010 Allison Transmission
Product Details:
- Brand: Pacific Performance Engineering
- Part Number: 129020710
- Country Of Origin: United States
- Warranty: Yes
PPE’s new Transmission Transfer Case Brace helps support the overhanging, heavy transfer case by spreading the load up and across the adaptor housing to the center section of the transmission.
PPE’s Transmission Transfer Case Brace utilizes two 304 stainless-steel 7/8 inch support tubes tied together with a thick 304 stainless-steel plate for increased strength and service life.
Mounting the brace is a quick and easy job that can be done without removal of the transmission or transfer case. No special tools required.
